Component vs coaxial, coax is higher grade
shnitz
Let's say that one is on a budget. Would it be better to recommend DB6501 over MM651? They're pretty much the same price, and I'm wondering whether it's better to have an MM-series speaker, or a component setup. Thanks in advance.
Post edited by shnitz on
Its like $50-100 more for the mm6501 why not just wait a week or 2 and get it? These are speakers that you will most likely have for years wouldnt it be worth it to get a better set? Also my MM6501 sounded okay with only 75 watts but then i gave them 200 and they are great so hope you have a decent amp.
Yes, the MM is a better line of speakers with better materials and design. So a better speaker line's coax will be better than a lower line's component most of the time. Of course there will be an exception or two out there but in this case, the MM's are the better choice.polkaudio sound quality competitor since 2005
