Need receiver advice
ddank
I need help finding a good receiver to go with my speakers and sub.
Speakers: RM7's
Sub: Velodyne DEQ8
I need something that can handle the crossover and make a smooth transition between the RM7's and the Sub. My current receiver doesn't have a 120 crossover setting (has 100 then 150) and given my speakers I think that's what I need.
What receiver would you suggest?
Speakers: RM7's
Sub: Velodyne DEQ8
Post edited by ddank on
What's your budget?
I'm thinking in the $600 range.
One other note: My tv is a 63" samsung plasma so I want to be sure that the receiver can handle the video too.
Thanks -
The Marantz 6005 is a nice one- http://www.amazon.com/Marantz-SR6005-Audio-Video-Receiver/dp/B003R7KMRE/ref=sr_1_1?ie=UTF8&qid=1310142748&sr=8-1
The new Pioneer 1021 has a TON of features and should sound good- http://www.amazon.com/Pioneer-VSX-1021-K-Theater-Receiver-Glossy/dp/B004M8RPBI/ref=sr_1_5?s=aht&ie=UTF8&qid=1310142815&sr=1-5
The Onkyo 708 is a nice choice as well- http://www.amazon.com/Onkyo-TX-NR708-7-2-Channel-Network-Receiver/dp/B003N197CU/ref=sr_1_13?s=electronics&ie=UTF8&qid=1310142887&sr=1-13
Denon 2311- http://www.amazon.com/Denon-AVR-2311CI-Multi-Source-Multi-Zone-Supporting/dp/B003MQLSMI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1310143266&sr=1-1
Yamaha RX-A800- http://www.amazon.com/Yamaha-RX-A800-7-1-Channel-Audio-Receiver/dp/B003XDU498/ref=sr_1_19?s=aht&ie=UTF8&qid=1310143187&sr=1-19
These are just a start, it comes down to the features you want and doing a little research about each brand and how they sound. Good luck -
My buddy just bought this Onkyo TX-NR709, all kinds of bell & whistle at $630, there's no way you can beat its value!!!
http://www.onecall.com/product/Onkyo/TX-NR709-Open-Box/Receiver/_/R-111094
Even though OneCall listed it as Open-Box, the receiver came out of the box in pristine condition, no sign of being used at all, and on top of that, full manufacture warranty.
Here's a little First Look: http://www.audioholics.com/reviews/receivers/onkyo-tx-nr709-flGears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
I'd be cautious about the Pioneer 1021. The recent issue of Home Theater test bench results were 46 watts per channel with 5 channels driver (.1% distortion). While that may be enough for you now, I believe it has no pre-outs so you would be stuck with it.
The Onkyo 609 (same basic power supply as the 709) on the other hand will get you 81 watts. The 709 will get you Audyssey MultEQ XT and the Marvell video chip which is nice.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
You are right the 1021 dosen`t have pre-outs , it starts with the 1120 . For the OP if you are not interested in 3D you should consider this options .I'd be cautious about the Pioneer 1021. The recent issue of Home Theater test bench results were 46 watts per channel with 5 channels driver (.1% distortion). While that may be enough for you now, I believe it has no pre-outs so you would be stuck with it.
Onkyo HT-RC180 at 349.99
Marantz SR5005 at 479.99 -
+1 on the Onkyo HT-RC180
also look into:
Pioneer Elite VSX-33 at ~550 (used/refurb)
Yamaha RX-V867 at 480 (new)
both support 3D. whether that appeals to you or not I don't know.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
How big is your room? I have the Onkyo TX-NR609 (previously had the TX-SR600) and they have no problem pushing any of the VM10s or RTi series speakers I have. I think the 609 would be powerful enough to drive the RM7s. I had looked at Dennon as well. it looks like they have a few options in the same price range. for me it came down to the size of the Receiver (depth) and the previous experience with my TXSR600. If we didn't get a new TV cabinet, I would still be running the 600 and just as happy.
the size issue was due to the cabinet being a slim 17inches deep (15 usable). My old receiver deeper than that. It needed at least 18" of usable cabinet space. Most of the Denons were all 15 deep and needed more depth with cords as well. The new Onkyo was comparable in power and had more features than my sr600 and was only 12 5/8 deep. I got lucky, otehr wise we would have to continue the painful process of returning and finding a hew corner cabinet which ther are very few that fit all our requirements.System:
Sony Blue Ray - BDP-S380
Comcast DVR - DCX3400m
Onkyo AV receiver - TX-NR609
Sony LCD TV - KDL-46V4100
Speakers:
Center: VM10
Front Left: VM10
Front Right: VM10
Subwoofer: Cambridge SoundWorks BassCube 8s
Surrounds: TBD - working on updating since a living room redesign and new receiver addition
Extras:
1 CSi30
1 CS175i
2 RTi38
Pair of FXi30
Onkyo TX-SR600 -
mccarthy814 wrote: »How big is your room? I have the Onkyo TX-NR609 (previously had the TX-SR600) and they have no problem pushing any of the VM10s or RTi series speakers I have. I think the 609 would be powerful enough to drive the RM7s. I had looked at Dennon as well. it looks like they have a few options in the same price range. for me it came down to the size of the Receiver (depth) and the previous experience with my TXSR600. If we didn't get a new TV cabinet, I would still be running the 600 and just as happy.
Can you explain to me why should someone pay more for a lesser receiver ???? -
agreed. the RC180 is a considerable upgrade over the NR609 for $100 less. If I'm not mistaken the rc180 is basically an NR807/707 minus a few HDMI inputs and another bell/whistle or two.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
I too have been looking into Onkyo recievers and have a TX-SR608 currently, what is your take on that reciever? I understand some had overheating problems. I am currently interested in a TX-NR5008 Onkyo reciever. Any info on that unit or first hand experience would be appreciated.
I'm thinking about pushing SDA CRS+ as the main fronts with it. -
I am not implying anyone should pay more for anything. Just providing information from my experience so far with the equipment I have.
I didn't see the Post for that HTRC180 before. Looks like an older model, I guess if it's available and you can get it cheaper, you should. Unless of course it's missing features you may want.
I've haven't seen any of the HT series receivers in stores around here (Metro/Boston). (I haven't been to every store though) I've only seen the TX series so, that's my point of reference. Generally, I like to see audio equipment and test it out before I buy.System:
Speakers:
Center: VM10
Front Left: VM10
Front Right: VM10
Extras:
1 CSi30
1 CS175i
2 RTi38
Pair of FXi30
Onkyo TX-SR600 -
I think the TX-SR608 is pretty close to the TX-NR609 I just got. I am happy with it so far. I haven't had time to try out all the features, but it's seems great so far. Mine has a fan in side of it, but I haven't heard it come on at all even when it seemed warm in the cabinet. Granted, i have't been pushing the receiver very hard.System:
Speakers:
Center: VM10
Front Left: VM10
Front Right: VM10
Extras:
1 CSi30
1 CS175i
2 RTi38
Pair of FXi30
Onkyo TX-SR600
