automatic pool cleaners
sda2mike
sda2mike Posts: 3,131
edited July 2011 in The Clubhouse
anybody use these? looking at the hayward..navigator, i think....there are other brands as well...recommendations?
thanks
mike
Post edited by sda2mike on
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2011
    I don't have one Mike, but I was looking real hard at the Aquabot Turbo. My pool is relatively small, I still manually vacuum it.
    http://www.aquabot.us/proddetail.php?prod=aquabot-turbo-pool-cleaner
    Helpful video:
    <iframe width="425" height="349" src="http://www.youtube.com/embed/hs8mVmVjaXQ&quot; frameborder="0" allowfullscreen></iframe>
  • vwfred69
    vwfred69 Posts: 54
    edited July 2011
    I had one, but I can't remember the brand. due to the way the jets were it made a pattern and missed big spots on the bottom.
  • pearsall001
    pearsall001 Posts: 5,251
    edited July 2011
    For above ground pools...the Pool Rover, I've had mine for about 7yrs & I wouldn't want to be without it. It simply works & works extremely well. For in-ground pools...the Aquabot as Steven mentioned. Both excellent products!
  • gdpeck
    gdpeck Posts: 840
    edited July 2011
    sda2mike wrote: »
    thanks
    mike
    I have a hayward navigator in a small ~12,000 gallon pool. When working correctly it is fantastic. I've looked into some other types of cleaners, but have been told that they aren't as good at covering the entire pool. I don't know if that is true or not. I also haven't looked into robotic cleaners at all. As long as I keep fairly fresh parts on the navigator it works well.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited July 2011
    I've had a Hayward pool vac (looks like the navigator), and I now have a Barracuda G3.
    I liked the Hayward, but it ate parts like crazy, to the tune of 75-150 bucks a year. It has parts that you will replace every year or two. All I've done to the Barracuda in the three or four yrs we've had it was replace the one moving part (diaphram) a few times, and it's 30-35 bucks.
    I think the Hayward does the job in less time than the Barracuda, but I'm willing to let the Barracuda run longer, knowing I won't have to spend near as much to replace it's parts.
    My equipment sig felt inadequate and deleted itself.
  • Jstas
    Jstas Posts: 14,978
    edited July 2011
    We had an AquaDroid for a long time. It worked well enough. I don't even think they are around anymore. I never liked how any of them did really and usually just ended up doing it myself.
    Expert Moron Extraordinaire
  • sda2mike
    edited July 2011
    thanks for the responses! now i wonder if it's really worth it...i vacuum manually once a week..maybe i'll save myself the trouble and just continue that way
    thanks
    mike
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    My pool came with a ladybug looking thing that did ok on the bottom of the pool but was unable to climb. My pool is a 27' round.
    It is just better to do it yourself.
  • eeagle
    eeagle Posts: 226
    edited July 2011
    I've had a couple of PoolVac's (now Navigator). First one I ran continuously except when swimming, and went through many feet and side flappers, but it did a great job; finally when many of the hose links leaked after several years I bought another one. Now I just put it in once a week for a day and have had no problems. The unit covers the whole pool with a non-repetitive random motion.
    I did try going back to manually sweeping for a while, but really liked the PoolVac automation and care free cleaning; but then I love technology and have a Mint Robot mopping my floors too (NorthStar controlled, never misses a spot).
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
