Dedicated stereo reciever for 2ch music. Where to begin????
ROHfan
ROHfan Posts: 1,014
edited August 2011 in Electronics
Wow, this is unbelievably tedious. I'm currently using an old Sony receiver to power my bass shakers but I recently got the idea to upgrade it to a more powerful and better quality stereo receiver. This way I can alternately use it to power my fronts (M60s) for listening to 2 channel music only. I really don't have the room or dough to go with an AVR with preouts and an external amp. My current avr is a Denon 1611.
I was thinking something like an HK 3485 or an Onkyo TX-8555. Used or refurbished would be ideal but there are SO many out there that I don't know where to start. My research has taken me in a dozen different diredAny suggestions? Thanks.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    Save up more money for an AVR with preouts.
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2011
    Depending on your budget, the possiblities are nearly endless.
    That said, the HK has pre-outs and is a good choice in it's price range. It also has two subwoofer outs. Check their e-bay outlet for b-stock at a great price.
  • dkg999
    dkg999 Posts: 5,647
    edited July 2011
    Nad c720bee
    DKG999
    edited July 2011
    All the suggestions above are good. I have an HK 3490 that does a fine job. Also have a NAD integrated that's an over-performer.
    I'd add the Outlaw RR2150 (no longer made, I think) but perhaps available used. Plenty of power and good feature set.
    The important thing is that they all have pre-outs, good power and sound and they can all drive a 4 ohm load!
    cnh
  • skrol
    skrol Posts: 3,448
    edited July 2011
    The older Denon stereo receivers are pretty good too. My DRA-835R and 825R from the early '90s have pre-outs and main-ins and don't mind 4 ohm speakers.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
    nooshinjohn Posts: 25,915
    edited July 2011
    If the purpose is a dedicated two channel rig, you cannot beat going with a vintage Pioneer SX 1980 or something from that family of recievers. Vintage Sliver faced Kenwoods, Black-faced Sansui, Pioneers or others from the golden age of high powered recievers. They can be found for a decent price and you would be hard pressed to find a current reciever that can hold a candle to some of the classics.
    The only drawback is that this gear is also ready to be refreshed(new caps, etc) so that should figure prominenetly in your descision.
  • ROHfan
    ROHfan Posts: 1,014
    edited July 2011
    Thanks, everyone, for the ideas. Except Joe08867 who was no help whatsoever.:biggrin:
    edited July 2011
    John has some nice suggestions above....but it should be kept in mind that the SX-1980 was the BEST stereo receiver 'ever' made by Pioneer--it retailed for over 1200 dollars in 1980 and weighed almost 80 lbs! And owners often try to sell it used for twice that price today! So 2000 dollars for a receiver? I don't think the OP is in that kind of price range.
    On the other hand you can get some nice vintage gear. I'm currently trying to pick up a Pioneer SX-3900 (120 W x 2) and 44 lbs of heft for a two way garage system. You can sometimes find these guys used from (100-150 or so). The problem! As John points out...it's 'age', caps, pots, etc. So you have to really check the product out. And be prepared for reconditioning.
    Good luck!
    cnh
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2011
    The rotel 1052 was awarded the best budget 2 ch receiver for its refined sound by tonepub . They sell for around $250- $350 used on ebay etc. The cool thing about the rotel is that its got a HT bypass so it would be good to go for a movie and its got plenty of inputs and power
    mhardy6647 Posts: 34,998
    edited August 2011
    soiled state/moderate-high power:
    (Yamaha CR-2020)
    vacuum tube/moderate power:
    (Fisher 500C)
  • ROHfan
    ROHfan Posts: 1,014
    edited August 2011
    I've heard good things about that receiver. How does it compare to an HK3490? That thing's supposed to be a beast.
  • kappclark
    kappclark Posts: 136
    edited August 2011
    I have an HK 3380 which I currently use as a preamp for a Parasound power amp... I drove a set of PSB Alpha's, before the Monitor 60's with the HK, and it was very pleasing..I think the 3490 is more powerful (the 3380 is discontinued)
    ** Bill Clark Windham, VT **
  • cristo
    cristo Posts: 231
    edited August 2011
    I have an HK 3480 that gets daily use (120 W/Ch 8 ohms 150 W/Ch 4 ohms)
    - also discontinued by now but works very well as a fairly inexpensive receiver
    (it was less than $300 when I got it new). The current offerings are the 3390 and 3490 (80 W/Ch $350 and 120 W/Ch $450 respectively - figure about 10% less actually selling prices).
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • DON73
    DON73 Posts: 516
    edited August 2011
    Yamaha receivers/amps have the ability to drive 8/4 and some 2ohm loads. My 2092 receiver can deliver 320 watts into 2 ohm loads for short periods.
    The Pioneer SX1010 at 100 watts can drive 4 ohm speakers easily.
    Both of these have pre outs.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
