BluRay player upgrade?
LandShark
Ok, right now I have a Sony S350 BD player. I'm always looking to improve the sound of my HT system. My question is, can the upgrade of a new BD player improve sound? I have an Onkyo 705 and it pretty much processes and decodes everything. Thanks!
TV: Samsung LN40A550
Mains: Polk Monitor 70's
Center: Polk CS2
Surrounds: Polk OWM3's
Receiver: Onkyo TX sr705
BDP: Sony S350
Subs: Velodyne VRP1200 and VRP1000
Monster Power Conditioner EP IR 2450
Post edited by LandShark on
In a general HT environment 2 BR players will decode the same formats so , right there you will have no improvement at all , now if you are interested in SACD or DVD upscaling , its going to be there the improvement , not on how your DTS Master track or PCM will gain any advantage ! You would gain more sound quality by making the transition from the monitor line to the RTi line .
Give Oppo players a try. They perform very well.Shoot the jumper.....................BALLIN.............!!!!!
If you have your Blu-Ray player set to bitstream, then your AVR is doing all the decoding. Therefore, you have basically taken the audio production out of the hands of your Blu-Ray player totally.
There is no need to buy anything to get better sound on the Blu-Ray player or AVR side since you Onkyo is sufficient in handling the demands of you current setup.
Someone suggested upgrading your speakers, I would look into this first.
Someone may know if picture quality is going to be a factor with your Blu-Ray player. I have not been able to tell the difference in that category between my PS3 and Pioneer BDP-330 Blu-Ray player, so I don't know in that regard.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
If you really want an upgrade in sound quality for H/T, then spending money will do it but not on the bluray player. I would look at getting a quality pre/pro and a power amplifier. This is going to cost quite a bit, but if you really want to go to the next level,this is what I suggest you do."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I think the only thing you'd notice is a possible change in video quality. As an experiment to troubleshoot an issue I was having with the audio dropping on BD movies I purchased another BD player.
The increased video quality was noticeable but no change in audio quality since the AVR is decoding it. I compared the video chip specs between the two BD players and the new one had better color processing and motion control. Both were Panasonic players. I boxed up the old one and sent it to my sister along with a few BD movies for her kids.
Next jump up for me would be an Oppo for a dedicated HT. -
Oppo's are over priced unless you have a large DVD collection and listen to SACD's, but the new Oppo 93 isn't like the 83 in DVD upscaling.
LG's I think give the most bang for the buck and have lots of online streaming features and play lots of formats. -
post #8 reportedI refuse to argue with idiots, because people can't tell the DIFFERENCE!
If your just talking HT, I would upgrade the speaks, maybe add an amp. Another BDP will be a sideway move. Music, if your using the BDP to spin cd's on, then a dedicated cdp, or a tubed pre amp will give you significant gains in SQ.HT SYSTEM-
lsi 9's -
Hi LandShark!
It's been a while. Tonyb has pretty much covered the bases. If you keep your speaker set and AVR which are similar to mine the only thing I would consider is a 5 channel power amp. That would be a step up.
I've run M-70s (etc.) off an Onkyo-605 and 805...they sound better with the 805 and they really sound good with a 200 watt power amp on them!
Look for something like a Parasound or B&K, etc. Check out the used market both 'here' and on www.audiogon.com
And enjoy. Hope everything is good!
Oppo all the way
or Panasonic DMT 210
