Marantz, Onkyo or H-K?
rebuy
rebuy Posts: 695
edited July 2011 in Electronics
I'm looking at the H-K 50 wpc
And the Onkyo 80 wpc
and a Marantz 5003 with 90 wpc
Which would you guys go for?
It will be running my rti 4's.
Which one will sound the best? :confused:
Post edited by rebuy on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited July 2011
    Gonna need the models to help you. I know that H/K actually rates their stuff accurately, sometimes even a little low.
    Blindly, I would ASSUME they would rank this way: Marantz > H/K > Onkyo, but again - all watts are not equal.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    edited July 2011
    What Onkyo is 80 watts? The 50X series?
    I'd go with at least the 60X series for those speakers (I use that myself). And if you can afford it, why not go one model up so you have have pre-outs in your future (70X)?
    I've heard Rti-4s on my HK 3490 and believe it or not (and this surprised me too), I preferred them on the Onkyo! Go figure, because the HK sounded better with a number of 'other' speakers!
    cnh
  • engtaz
    engtaz Posts: 7,669
    edited July 2011
    Marantz great sound
    Onkyo better bells and whistles.
    HK not had one in my house yet.
    engtaz
  • Marty913
    Marty913 Posts: 760
    edited July 2011
    Any one of them should have enough power to drive the RTi4's. The watts however have nothing to do with "which one will sound the best". Only you can decide that. Model numbers might help (especially with features) and cnh sounds like he has some experience with the RTi4's. Other than that you will probably just get a lot of generic brand preference opinions. I think you're going to have to go listen to a couple of them. The Marantz & HK will probably sound somewhat similar to one another, the Onkyo will be different.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2011
    Marantz gets my vote of these choices.
  • Systems
    Systems Posts: 14,873
    edited July 2011
    H/K,Onkyo, or Marantz...Three good choice's..H/K's have (warm)..sound.All three are all high current.. anyone of these would do you well.As much as i like my H/K's because i just like the way H/K's sound..my vote would be for the Marantz with RTi4's..The post here are stop on about any of these.
    Testing
    Testing
    Testing
  • B Run
    B Run Posts: 1,888
    edited July 2011
    Really depends on the model, i've had all three this month and like the Onkyo the best. Try to get your ears on some so you can compare before you buy if it's at all possible.
    gudnoyez Posts: 8,161
    edited July 2011
    I would go Marantz also.
  • Systems
    edited July 2011
    ctank wrote: »
    H/K,Onkyo, or Marantz...Three good choice's..H/K's have (warm)..sound.All three are all high current.. anyone of these would do you well.As much as i like my H/K's because i just like the way H/K's sound..my vote would be for the Marantz with RTi4's..The post here are spot on about any of these.
    :cool:
    Testing
    Testing
    Testing
  • rebuy
    rebuy Posts: 695
    edited July 2011
    Thanks for all the input. After looking and pondering for awhile, I went ahead and bought the Onkyo TX-SR608. Since It was available for 213 to my door I thought it was my best option. Now I have to buy the rest of the speakers for the system.
  • seeclear
    seeclear Posts: 1,244
    edited July 2011
    I think you will like the oinker. I have onkyo in the bedroom 5.0 rig, and HK in the home theater, 'cause I could get a good deal on it with HDMI and preouts. Never really impressed by the HK in the theater. I know you shouldn't notice the surround content that much, but I never get the feel that I am enveloped in the action/sound, as the surround content it puts out seems very weak; while I do get that feeling with just 5.0 in the bedroom. I even went in and turned up the volume on the surround speaks, and still little to nothing. Also, and this may be part of the problem, it doesn't seem to pick up the Dolby D content from the Directv receiver, which the oinker does. But I do notice the surround content weak even on DVD which does show up as Dolby D on the display. Oh well, good luck.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • engtaz
    engtaz Posts: 7,669
    edited July 2011
    I see the bells and whistles win out. Onkyo is not bad at all.
    engtaz
  • rebuy
    rebuy Posts: 695
    edited July 2011
    Yes, I did go for the bells and whistles but I figure the Onkyo was plenty of power for rti4's.
    Since I do not have up-grade fever, I think for bookshelves will be fine with this receiver.
    I have been running the 4's through a Kenwood VR-615 that a friend loaned me a month ago and it is so weak, 100 WPC, yeah right! Running amps this lame will give you upgradeitus. At least when I get the Onkyo my 4's will be closer to be broken in since I have used them for over a month.
    The sound from this Kenwood is Dismal.
  • engtaz
    engtaz Posts: 7,669
    edited July 2011
    Congrats
    engtaz
