Audiosource 210 Amp in MONO/Bridged mode?
S T R Y K K E R
S T R Y K K E R Posts: 77
edited June 2011 in 2 Channel Audio
!!!!!!!!!!!!!!CORRECTION____________CORRECTION ITS the AUDIOSOURCE 110 insted of 210!!!!!!!!!!!
I have found 3 Audiosource 110 Amps locally that have hardley been used for $300 for all 3 :biggrin:
I was saving back some cash for an XPA-3 for $700,but If I were to buy the 3 Audiosource Amps and bridged each one of them ,each amp would output 225watts to its own speaker........which would be plenty of power for my Monitor 70's and CS2!
+++ It will save me some $$$$$$$$$$$$ $400 to be exact......my question is are Audiosource Amps good quality amps?
If the feedback is good in here about these amps im gonna jump on this deal quickly before their gone..........
16' x 12' Man Cave :smile:
Onkyo TX-NR1008 9.2 AVR
Polk Monitor 70's--Mains
Polk Monitor CS2--Center
Polk Monitor 30's--L/R Height's & L/R Wide's
Polk Monitor 30's--L/R Side Surround
Polk Monitor 30's--L/R Back Surround
(3)BIC Formula-12--Sub's
(4)Aura Pro Bass Shakers with Crown XLS 1000 amp
Emotiva-XPA-3 AMP for L/C/R
Epson 8100--1080p LCD projector
120" Elite Screen-- High Contrast Gray
Sony BDP-CX960--400 disc BLURAY player
Sony DVP-CX995--400 disc DVD player
XBOX 360 & PS3
Post edited by S T R Y K K E R on
  • Conradicles
    Conradicles Posts: 6,377
    edited June 2011
    I think they are great H/T amps...I've used one for a few years with no problems at all...the AMP300 model.
  • S T R Y K K E R
    edited June 2011
    Conradicles...would it work the way I think it would?I want to use each amp individually- 1amp for left,1amp for right,1amp for center and bridge them all so they would output 225 watts per speaker.......would it be that simple? for 300.00 if it works then im set.
    XBOX 360 & PS3
  • Conradicles
    edited June 2011
    Yes that will work perfect as long as the speakers are 8 ohms which I think those models are.
  • kefranklin
    kefranklin Posts: 141
    edited June 2011
    It should work fine with 8 ohm speakers. I have two Audiosource amp threes and they have served me very well. Not super high end, but solid and much better than a receiver. I have heard from some people that the original Amp One was more reliable than the newer 110, but I don't know why this was said really.
  • stangman67
    stangman67 Posts: 2,328
    edited June 2011
    I had an old Audiosource 300 and loved it to death. The are made by Phoenix Gold or the same company that builds the older Phoenix Gold amps. Good stuff
  • inspiredsports
    inspiredsports Posts: 5,502
    edited June 2011
    amazon.com currently has the 110 for $209 delivered to your US address. Parts Express is $359 + S&H.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
