MM 1040 DVC Wiring Help
Hanks2500Hanks2500 Posts: 7
edited June 2011 in Car Subwoofer Talk
How should I wire my single MM1040DVC to my Kenwood XR-5S
5-channel car amplifier which has 80 watts RMS x 4 at 4 ohms for the speakers and 350 watts RMS x 1 at 2 ohms for the subwoofer? Thanks
Post edited by Hanks2500 on
  • Hanks2500Hanks2500 Posts: 7
    edited May 2011
    Never mind, I found out online how to wire the 4 ohm dual voice coil sub to a 2 ohm amplifier. Thanks
  • koodokoodo Posts: 3
    edited June 2011
    bump... I want to buy a mm1040 dvc but the polk website says both the SVC and DVC are 350w RMS but the spec sheet contradicts it... saying DVC is 270?
    Just want to know how much RMS is ur's?? and how does its sound? (+ sealed or ported)
Howdy, Stranger!
