Antimode 8033S
Erik Tracy
I'm in the market for an Antimode 8033S SubEQ for my 2-channel setup.
If you have any leads - I'd appreciate it!
Post edited by Erik Tracy on
Not an Antimode but I noticed SVS has a B stock AS-EQ1 for $649. I've heard good things about them...
https://svsound.com/store/index.cfm?fuseaction=category.display&category_ID=12 -
ken brydson wrote: »Not an Antimode but I noticed SVS has a B stock AS-EQ1 for $649. I've heard good things about them...
Ken,
Thanks for the lead - a bit pricey for my budget.
Oddly enough the US distributor for the Antimode is in SD, just down the street from where I go for martial arts - I may drop in and see if they can make me a deal.
Saw that.
Not sure on compatibility for my setup.
I want to use the antimode for my 2-channel setup. L/R Stereo Preouts from my integrated to the antimode.
According to their website only the "S" version supports this, not the "C" :frown:
Thanks though!
Erik Tracy wrote: »Saw that.
Thanks though!
My bad, don't know much about them. Good luck in your quest... -
i've got one of audiogon if you are still interested...
Really? Where?
I thought they were all sold or were the "C" model?
