What do you think of this Monitor 7 crossover upgrade kit from ebay?
xenonsky
Here's a set of Monitor 7 series two crossover upgrade kit I found on ebay.
http://cgi.ebay.com/Polk-Audio-Monitor-7-series2-Upgrade-Kit-/180612653513?pt=Speakers_Subwoofers&hash=item2a0d5a61c9
What do you guys think of it? Any good? I'm thinking of giving it a try as I have Monitor 7 series 2 with sl2500 tweeters.
Cheers,
xenonsky
Cheers,
xenonsky
Post edited by xenonsky on
I think it would be better to leave them alone than use mediocre parts to upgrade my speakers.
This idea has been discussed many time on here and I believe the general consensus is by higher quality parts from Sonicap or Clarity Cap and enjoy.
These ebay kits are made with cheap caps at a decent price but it isn't really an upgrade as much as an update and even that is questionable. -
I'm sure the "modifiaction" manual will come in handy
Ludicrous gibs!
