Can I bridge my SDA-1C speakers?
  • SDA1C
    SDA1C Posts: 2,072
    edited June 2011
    sort figured it was a moot point but had to ask. I honestly wouldn't have a valid use for one other that to say I had one. I've caught a glimpse of the innards and it way over my head. At any rate. sounds like heiney got the op straightened out a bit. Or as Dad used to say UTRFTS or UTTAIS. lol
    Too much **** to list....
    F1nut Posts: 52,008
    edited June 2011
    003 wrote: »
    My receiver is set to 4ohm mode which is just a current limiter and I have the volume capped at -5dB. If I bridge them, I will still leave it in current limited mode.
    You are starving your speakers. Current is what they love, so put your AVR back to 8 ohms and just forget all about bridging.
    F1nut Posts: 52,008
    edited June 2011
    003 wrote: »
    Can't someone that has a copy just scan the pages and upload it?
    No, it is a copyrighted publication.
  • FTGV
    FTGV Posts: 3,650
    edited June 2011
    SDA1C wrote: »
    When I first purchased mine they were 6.1 nominal. Actually I was a bit surprised a moment ago to read 4.0. Is this any point of concern?
    What you would have been measuring is the DC resitance of the woofer(s) and any inductors (and wiring) in series with them. The DCR is usually an ohm or more less than the stated nominal impedance which adds the effects of reactive components(capacitance and inductance) to the resistance.
  • 003
    003 Posts: 19
    edited June 2011
    Assuming that I can't get the AI-1 cable, are there instructions anywhere to make my own adapter?
    Looking at this picture:
    Can anybody link me to a suitable transformer, and also regarding those eight wires coming off the transformer, where do those get connected? I don't have much knowledge about this sort of thing. How large a transformer do I really need to make it work?
  • gdb
    gdb Posts: 6,012
    edited June 2011
    gdb wrote: »
    Brand new, never used AI-1 interface unit available. PM for info.
    The AI-1 has "left the building", thanks 003! If the sales rating system ever gets fixed I'll write you a + :wink:
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2011
    003 wrote: »
    Ummmm...yes. I gave you the link in an earlier post.
    Schurkey wrote: »
    If he builds an AI-1 to the same specs as the OEM Polk unit, it would be about fifty bucks, maybe less. The raw transformer would be something like $20--$25 shipped, plus some cables and terminations.
    http://www.polkaudio.com/forums/showthread.php?t=55888 Post #6.
    Additional info:
    The OEM Polk unit is good for .13 amps; and that is NOT enough...but it was good enough for Polk at that time. Any suitable isolation transformer than can handle more than .13 amps is almost certainly better than the OEM unit. Using the "Dreadnaught" style, at something like 6 or 7 amps is quite superior...but not absolutely required.
    003 wrote: »
    I'd say an isolation transformer of the OEM size as a MINIMUM; but better would be to go with the Dreadnaught-style pioneered by Darqueknight.
    http://www.polkaudio.com/forums/showthread.php?t=74472
    Lots of reading there.
    PS: If you're using current-limiting, you're very likely making a mess of the sound quality.
  • 003
    003 Posts: 19
    edited June 2011
    I have acquired a BRAND NEW AI-1 cable, and it's terminations are both pin/blade. I hope it works! If not they do seem to have a decent demand.
    Anyway, I don't know the technical operations behind audio, so exactly what benefit does a transformer rated for higher amps provide? Surely the polk implementation must work, or they wouldn't have offered it. Will it somehow not sound as good as a larger transformer, or I won't be able to turn it up as loud?
    F1nut Posts: 52,008
    edited June 2011
    Schurkey wrote: »
    He's doesn't seem to be getting that point.
  • Schurkey
    edited June 2011
    003 wrote: »
    The electrical signal that "powers" the SDA system is dependent on two things: the volume level you're listening to, and the difference in signal between the left channel and the right channel. In other words, the music (or speech...or noise) you're listening to, and the volume level you've chosen for playback.
    The most difficult possible load for that transformer, I suppose, is to have one channel of LOUD music, while at that instant there's silence in the other channel. There'd be maximum difference between the channels, and a lot of voltage driving a lot of current.
    The Polk AI-1 transformer has a capacity of .13 amps. But that's WAY less than the plain ol' interconnect is capable of transmitting. If you look at the Dreadnaught link posted above, Matthew Polk Hisself has proclaimed that "ideally" the transformer should be capable of transmitting 5+ amps.
    You now understand the situation. The transformer "should" have a 5+ amp capacity, but due to the enormous expense and shipping weight, the AI-1 in production form was reduced to a shadow of what it should have been.
    003 wrote: »
    You're right. It "works". But the tiny transformer will saturate at a low volume level; and of course the whole shebang was compromised in terms of parts quality. You will be able to use it with your bridged receiver; nobody is making any guarantees that the result will have the sound quality you're hoping for.
    As for whether "your" 1Cs are AI-1 compatible, I'd be looking to see that there's essentially zero ohms between the blade socket (not the pin socket) and the negative terminal of the speaker. If you've got a very-low-resistance connection there, your speakers should be AI-1 compatible. If the blade socket has more than about one ohm resistance to the negative terminal, bets are off. It really ought to be a dead short.
  • 003
    003 Posts: 19
    edited June 2011
    No, I didn't miss that point, I will turn off the current limiter :biggrin: I only had it on because I heard that these speakers can be hard on amps, but I will still leave the volume capped at -5dB and I do have a 5 year warranty, so we'll see how it works out.
    Schurkey wrote: »
    Thank you! I measured with my DMM and the negative terminal and blade socket measures ZERO ohms for me! To make sure it wasn't broken I also tested with the pin socket and it instantly showed up as 14 ohms, so hopefully I am good to go! I am aware the AI-1 may not be the greatest, but I will test it for myself. I'd rather not have another box that I don't have room for. I need to work with what I've got ... which unfortunately isn't the greatest, but could be worse.... hopefully. My receiver was the best Onkyo made at the time I got it and is actually specifically advertised as high current.
    gdb wrote: »
    I look forward to it, thanks!
    EDIT:
    By the way... quick question about speaker placement. All guides I see for home theater setup say that the front speakers should be angled in slightly at around 30 degrees, facing the focal point of the home theater. Is that true for the SDA-1s, or is that not good due to the SDA effect?
  • gdb
    gdb Posts: 6,012
    edited June 2011
    If you're getting cold feet about the AI-1 purchase just let me know. I don't want you to regret buying it.:wink:
  • 003
    003 Posts: 19
    edited June 2011
    gdb wrote: »
    No, now that I know it should work, and will require no assembly on my part, and should fit in the small space I have available, I think I'll be OK. Thanks! :biggrin:
  • headrott
    headrott Posts: 5,496
    edited June 2011
    reported.
    F1nut Posts: 52,008
    edited June 2011
    Never toe in SDA speakers.
    heiney9 Posts: 25,510
    edited June 2011
    003 wrote: »
    So who verified that your 1C's can even use the AI-1? I must have missed that post. Good luck.
    edited June 2011
    003 wrote: »
    There are very specific instructions for setting SDA's up properly. The closer you follow the guidelines the better they will sound. As F1 stated no toe in at all.
  • 003
    003 Posts: 19
    edited June 2011
    heiney9 wrote: »
    Two modes of verification :)
    First, it was suggested I measure the impedance from the blade socket to the negative speaker terminal, and if it was zero, it should work. It was in fact zero.
    Second, I found a picture of the list that says what SDA-1Cs work with it here:
    http://www.polkaudio.com/forums/showthread.php?t=70236
    I am in the clear by a long shot :D
    Thanks, I'll be sure not to do that!
    edited June 2011
    Well, you're set then!
    Just an FYI, almost all the information contained in Darqueknight's SDA Compendium is on Club Polk somewhere. That's one of the main reasons he decided not to do another edition. Granted, having the info in one easy to use binded book is much more convenient obviously, but there aren't any "secrets" in the Compendium that aren't here somewhere in the archives.
