MW8002 - help
LeStat
Does anyone have an MW8002 they are looking to part with or know where one can be gotten?
If the MW8002 is too rare or hard to get then does anyone know if there is a driver that would be a good replacement in a pair of RT10's? Does Polk have an 8"driver that would be a good fit to simply swap out.
Any help would be appreciated.
Thanks!
Thanks!
Post edited by LeStat on
Pretty hard to find.
I would keep an eye on Fleabay, as they come up there occasionally.
The RT-7's used the same woofer.Testing
Testing
Testing -
I have two (2) MW8002's new in the box. It wouldn't be a bad thing to have a spare on hand as they are sort of hard to find.
Thank you Acolive
what do you want for them?
How do i contact you outside this site?
Where are you located? -
does anyone know how i can contact Acolive?
I sent him a private message on this post but no reply.
Any help is appreciated.
