Monitor 70s - large or small with sub?
I'm using monitor 70s as fronts with an F12 subwoofer in a 3.1 configuration. After running automatic configuration on my receiver, it set the 70s to "large". However, some people suggest that the sub should handle all the bass and I should manually set the fronts to "small". This seems to be a bit of a waste of the 70s! From my limited listening tests so far, I don't hear a big difference between having the 70s as large or small. What do the polk experts here suggest? The system is used for a mix of both stereo audio and HT.
Thanks.
Post edited by starless on
  • kevhed72
    kevhed72 Posts: 5,139
    edited March 2011
    I had my fronts set to small for awhile, then tried switching them to large, and actually liked it a bit better & left them on large ever since.
    Do some more comparisons and see what sounds better to you...:smile:
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2011
    Yeah, I run large on my front as well for HT. Moves more air that way.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • starless
    starless Posts: 23
    edited March 2011
    quadzilla wrote: »
    So, it sounds like you're using both the 70s and the sub for bass. With the 70s set to "large", my receiver by default only uses the sub for LFE.
  • Issa
    Issa Posts: 20
    edited March 2011
    starless wrote: »
    Most receivers will allow having the low frequencies to play thru Large and the subwoofer continuously. Check for a setting under the LFE mode to something like 'LFE+Main' or Subwoofer 'Plus'. If Speakers=Small or the Sub=No then the setting might be grayed out.
  • whitefish01
    whitefish01 Posts: 13
    edited March 2011
    My Onkyo has "Double Bass" which I like. I have my monitor 70's set to large.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2011
    +1 for Large for the M70's with subwoofer set to "Plus" or whatever your receiver's equivalent is! Then you can play with the subwoofer crossover point to get the distribution of low bass the way you like it (usually, you'd set it pretty low like maybe 60Hz then).
  • markwoll
    markwoll Posts: 3
    edited March 2011
    My Yamaha YAPO set the M70 to large, which cut out the sub.
    I set them to small which kicked the sub on, didn't like the sound too much.
    Then I found their version of 'Double Bass'.
    I like the sound better, but I am working on the correct level and crossover point for the sub.
    Love the M70's.
    mark.
  • quadzilla
    edited March 2011
    The correct xover point will depend entirely on your set up, your room, and your tastes.
    Arm: Rega 300
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    I switch mine back and forth a lot. Don't know what I like better.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • djperez81
    djperez81 Posts: 388
    edited March 2011
    I agree whitefish i like the double bass feature on my onkyo i have my 11t's set to large and double bass on and its sounds great for HT and even better when its in 2ch since i recently added a 2ch amp for my front L/R.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • over50
    over50 Posts: 201
    edited May 2011
    I tried setting my M70 to full yesterday and i couldnt hear the subwoofer.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • pearsall001
    pearsall001 Posts: 5,257
    edited May 2011
    Here's a great article on the subject: http://forum.ecoustics.com/bbs/messages/34579/128214.html
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2011
    I always enjoyed running my sub at line level. I used a Y cable from each pre-out, one line went to my amp and the other went to my sub. That way your fronts and Sub get the full signal. Some subs will allow you to do this with speaker wire. But this might be a bad idea if your sub does not have its own Xover.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • packetjones
    packetjones Posts: 1,059
    edited May 2011
    It depends on what power amp u have and the quality of your sub really.
    If you have say the 70's and a psw10 then plus/large would probably be the best option. But if say you have a svs ultra or epic then you would probably want to set the 70's to small. Same with amp power. If you are using an avr then there is limited power and may not pun the 70's very well. Whereas a separate amp with good power could make the 70's hit pretty hard bass wise.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • JimAckley
    JimAckley Posts: 1,138
    edited May 2011
    Is that the BIC America F12?
    I would run your sub at or near its lowest crossover point, and only make it add the lowest bass to your M70s. Like everyone else mentioned, you'll need to set your receiver "double bass", "Plus" or whatever mode it is that will output the bass to not only your LFE output but M70s as well.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
