How would you....
VR3
My Dad just ordered an Outlaw Audio 950 to replace his old Yamaha DSP/Preamp...
It is a two piece unit, and the DSP part has built in center, and surround amps...
I am getting a 30 year old JVC from our video store in April, and I am curious if there would be a way to wire the DSP and JVC together in some way where you could use the JVC for main channel, and the DSP for the surrounds and rears? Is there a way, and if there is - what would I be looking for?
I can't tell you what is on the back fo the JVC for I dont know.
Post edited by VR3 on
I think that would work if the JVC has preamp inputs, and then you have to match the gains with an SPL meter.Graham
sounds good to me, I figured that much -- anyone else know something different?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
