B&k av6.5.4
KrazyMofo24
I picked up this amp at a local flea market today. I currently have a B&K ST-202 for 2-channel and would like to use the AV654 to power my Haydn's as surrounds and eventually a center channel.
I wanted to know if anyone knew if this was a quality amp and would it go well with the ST-202. Also I would like to bridge it to a 3-channel amp. I'm not how sure I would wire it to bridge it. Any help would be appreciated.
Here is the link to the manual.
http://www.bkcomp.com/fileadmin/content/content_products/manuals/Past/Amp/AV%20654.pdf
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
You're going to need a service manual, but the general idea is that you flip the phase on one of the channels in a pair and strap the negatives together. You'll also need to set the gain on full for the bridged channels or bypass those pots.
It may be as easy as flipping one wire's polarity, but don't go doing anything without the service manual or finding someone who knows about that model.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
