xover diff. rta 12b's
soundfreak1
A friend just aquried a pair of 12b's. Though the board looks the same at first close inspection his has diff. Inductors (mine white, his yellow) and his board dosent have a fuse where mine does. This may be a ? For geppy1 but is the diff in these xovers?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
There are two different crossovers for the 12's. The 12A has both mids going through the tweeter circuit and the 12b's have just one going through the tweeter circuit.
Polk was also known to change things on the fly from time to time on all there crossovers.
If you can get a pic of both to compare I think we can better answer your question.
By the way the inductors are the red wire wrapped around an iron core. The yellow and white things you speak of are capacitors, and there may be no difference at all. It depends on what they say on them. If the actual values are different or not. Polk uses outside suppliers for there crossover parts and they come in all different colors. -
Where are you reading that it is a 12B??? Do not go by what it says on the the top board to decide B or C. Look at the serial number on back. What is it?? They removed the fuse and went to a Polyswitch when they went to the SL2000 which is late 1985.
My 12C's do on both the upper and lower crossovers
"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Both pair have sl1000 tweets my pair are dated 1983 and have the fuse waiting for my friend to ck his dates but there is no fuse. Both are marked in s # and on xover.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The only number that matters is the one on the back of the cabinet
Both speakers are 12b's (no issue) just courious why 1 is fused on xover and 1 is not and why. They look identical( xovers) execpt the fuse and the inductors are a diff color.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
