New test gear.
[Deleted User]
[Deleted User] Posts: 7,598
edited May 2011 in Electronics
Hello,
I bought a Sound Technology 1510A tape recorder test analyzer that can automatically do frequency response, 2nd and 3rd distortion, signal to noise, channel separation, check playback head azimuth, wow and flutter and store data in a digital memory for comparison. Previously I had to make dozens of individual frequency measurements, then convert the voltages to dB and hand draw a graph. This device can do all of that and so much more with a built in test procedure. Fortunately it comes with a well written operator's manual and I'm still learning. I needed two Magnetic Reference Laboratory test tapes to do some of the tests, they should get to me on Friday.
Cheers, Ken,
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2011
    Cool new toy Ken. Makes tweaking head alignment much easier I bet.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2011
    Fine piece of test gear, congrats! :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • [Deleted User]
    edited May 2011
    Yea, head alignment was always something that I didn't feel comfortable doing. Now it should be much easier, it uses the phase relationship between the right and left channels as they play a test tape. You're supposed to make the adjustment so one of the display's bars gets smaller and smaller. It will also calculate the number of dropouts per a certain amount of time. If I could find the original test LP I could make turntable tests, but those are impossible to find.
  • megasat16
    megasat16 Posts: 3,521
    edited May 2011
    Very Nice Instrument! A must have for serious Vintage junkie.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • madmax
    madmax Posts: 12,434
    edited May 2011
    Ken finds all the cool stuff...
    Vinyl, the final frontier...
