A question of Pre-amps
renowilliams
renowilliams Posts: 920
edited May 2011 in Electronics
Currently I am using a Pioneer Elite 49 TXi as a pre with a Rotel RB-870 BX amp. I am wonderring if I got a Rotel RSP-1066 Pre whether I would see improvement in 2 channel mode.
If any of you guys using Rotel separates could comment, I would appriciate it.
Tim
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Post edited by renowilliams on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2011
    Don't know your budget? But if you can handle about 400.00 get a darad sl2000a tube pre. Simply the best soundind pre I heard for less than double the price new.must upgrade tubes though. This pre will change your life!! Not to mention your system! You can run both amps on this pre and it is a remarkable value! But more info needed as to what you want it to do for your sys. To advise with any detail.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • sucks2beme
    sucks2beme Posts: 5,691
    edited May 2011
    Tim
    Rotel sings with Rotel. There are others that work well, but for some reason
    the best my rb-980 ever sounded was with a Rotel pre.
