B&K or Rotel?
footwedge
footwedge Posts: 475
edited May 2011 in Electronics
Looking for an amp to power LSI 7s, LSI C center and LC60i in wall surrounds, all of which are gathering dust until I get the amp. I'll be hooking the amp to the ONK TX-SR701.
It's between the Rotel RMB 1575 or the B&K 200.7. Leaning toward the B&K but concerned with: how hot they run? and are they still being built? The unit will be in a closed cabinet. Also, 2 of the channels will connect to zone 2 speakers on the deck.
Please understand this will be my first venture into the amp world and would appreciate any advice.
Post edited by footwedge on
    pitdogg2 Posts: 26,961
    edited April 2011
    get your ears on them some do not like the sound of the new Rotel digital amps.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    Look at the Rotel RMB-1075. It's a great performer and it's budget friendly.
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2011
    I don't think you could go bad with either amp. I personally never had the running hot problem on any of the B&K amps I have owned.
    It also depends on the sound you want. The Rotel is more sterile to me which isn't bad and maybe even more accurate but I prefer the little extra warmth I got from B&K.
  • nguyendot
    nguyendot Posts: 3,594
    edited April 2011
    I run Rotel and love it. But B&K is nothing to scoff at.... You really have to just hear them and make your decision in this case.
    Main Surround -
  • footwedge
    edited April 2011
    Unfortunately the closet dealer is 400 miles.
  • footwedge
    edited April 2011
    Joe08867 wrote: »
    Joe, is your B&K in a closed cabinet? Just from researching class A A/B amps and reading comments on here, the hot/warm issue has been mentioned. The amp will be on whenever the TV is running which could amount to extended run times.
  • Joe08867
    edited April 2011
    I had one in a TV stand and the other was on an open audio stand. Neither got hot. Warm? yes but never hot.
    It also depends on the volume you play them at. If you have it cranked up the whole time almost any amp will get hot. But sitting idle or at normal listening levels it should be fine. Just make sure there is a couple inches of room above it for heat to dissipate.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2011
    Either one of those amps will make your speakers sing. I wouldn't use a 1075 for an all LSI system. The more power the better.
  • zx_toth
    zx_toth Posts: 417
    edited April 2011
    I run a Rotel 1080 for my LSi25s and a Rotel 1085 (Class D amp) on the center LSiC and 2 pairs of Rtia series speakers for surrounds. I do not note any ill effects of the Class D amp on the LSiC for sound quality but of course I am using this HT not critical music listening sessions. I would feel comfortable with running my LSi25s on a Class D amp though.
    Z
  • MADGSF
    MADGSF Posts: 603
    edited April 2011
    I have a B&K 7250 and have run it with a normal open TV stand in the past and an enclosed cabinet currently. Unfortunatley I never checked the temperature with the open TV stand so don't know how it compares.
    I am not sure what is considered hot but in my cabinet with no ventilation the temp on top of the amp was 110 degrees or more. There was an opening for ventilation so it was not completely enclosed. I then added active ventilation, two exhaust fans, and the temp on top of the amp went down to 100 degrees or so. I then added two more fans that pull air across the top of the amp and it runs about 95 now. Note this is during the winter when the room temp is in the low 70s. In the summer I have to open the cabinet door to keep the temps in the 95 range even with active cooling.
    In my opinion if you are putting it in an enclosed cabinet you should find a way to monitor the temperature to make sure active cooling is not needed. As far as sound goes I have heard the B&K sound with LSi and to me it's wonderful. I have never heard a Rotel digital amp. I picked mine up used and have no issues but B&K is bascially out of business if that is a concern.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • Emlyn
    Emlyn Posts: 4,638
    edited April 2011
    Although B&K went out of business, its products are on the way back to market because the company was purchased by ATI.
    http://www.bkcomp.com/
    The 200.7 is a powerful 7 channel class A/AB amp, the Rotel a class D (switching) amp. I've had B&K amps run warm, not really hot. Class D amps should produce almost no heat.
  • danz1906
    danz1906 Posts: 5,144
    edited April 2011
    Go for the B&K 200.7!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • footwedge
    edited April 2011
    Emlyn wrote: »
    Maybe in certain areas but the one retailer I talked to said that he has not been promised any new products.
    As for the cabinet being closed it actually has a removal back panel with slots maybe 8"L x 2"w at the top and bottom of the 2 end sections.
  • sm88
    sm88 Posts: 353
    edited April 2011
    I've owned the Rotel 1075 and Rotel 1070 and both were quite excellent through Paradigm Studio speakers. Very well built amps.
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • leroyjr1
    edited April 2011
    sm88 wrote: »
    I ran my lsi 9's ad 7's off the rmb-1075 and it did a great job. No need for a ton of power the 7's and center is fairly easy to drive.
    The RMB-1095 is also a great amp in the $1000 range. It has a ton of power but is very heavy.
  • dougr
    dougr Posts: 124
    edited April 2011
    I ran the older AV5000 (5x105W) to drive 4xRT16 1xCS350 and it sounded great... warm at all times, very warm midway through loud movie, but not what I would call hot. I however, would not feel comfortable enclosing it with no ventilation. Is there any way you can get airflow through your enclosure? I've hooked up multiple 12V computer fans for this purpose before (you can get relatively cheap ones that move a decent amount of air without much noise).
    ______________________________________________
    RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable :)
  • pearsall001
    pearsall001 Posts: 5,246
    edited April 2011
    You can't go wrong with either...grab the one you get the best deal on.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited April 2011
    My 7270 SII gets pretty darn hot... I'd be worried about keeping it in an enclosed space.. though it has had no problem running all day.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2011
    Personally I like B&K better. YMMV.
  • footwedge
    edited April 2011
    Since I will never go to 7.1 and the 2 additional channels are for the deck speakers (zone 2), would it be wiser to get a 5 and a 2 channel amp verses the 7 channel?
    Can you buy b&k through the net?
  • Emlyn
    Emlyn Posts: 4,638
    edited April 2011
    You'd only find B&K right now through the used market (Audiogon, Ebay) unless there is new stock among some of the dealers still. Prices on their used gear seem to be down a lot since the company went under. ATI may bring new B&K products back on the market later this year. They have stated their intent to support a dealer network, so online sales are not likely if that happens.
    I actually preferred using a lower powered 5 channel amp for center and surround speakers and a separate more powerful 2 channel amp for the main speakers. I had a B&K 7270 amp for a couple years but found it was really overkill for surround speakers, even the Polk LSiFX's.
  • aboroth00
    aboroth00 Posts: 1,106
    edited April 2011
    Why not take a look at ATI? I'm a big ATI fan and they make solid amps in Socal. If you do buy BK, you're not going to get a lot of support from ATI however. I met a guy who purchased an ATI amp from me and commented that the ATI techs couldn't help him after he blew his B&K.
    2Ch Tube Audio Convert
  • footwedge
    edited May 2011
    After further research, I'm now looking at the w4s multichannel amps for several reasons: weight, coolness and can be delivered to my door. Also looking at the Dac2.
    Would the 7 channel with 3@550-4ohms for the fronts and 4@220-4ohms for the rears and zone 2 be sufficient?
    I would also like to upgrade the oink and sony cd/dvd player (DVP-NC600). So, if I get the dac2 what pre and blue ray/cd player would you recommend with similar price points of the other equipment? Would the SC-27 work? or would it be overkill along with the dac2?
    Hope this is not confusing. I've been doing a lot of reading and I think I might have overloaded my brain; but, after finally acquiring the LSI speakers, I'm ready to overhaul everything and need expert advice.
  • renowilliams
    renowilliams Posts: 920
    edited May 2011
    I'm not sure about what your willing to spend on a bluray player but I can highly recommend Oppo. I love mine. Some BDP-83's have been comming up for sale used since the 93 and 95's came out.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • sm88
    sm88 Posts: 353
    edited May 2011
    footwedge wrote: »
    That's plenty of power, a lot more than you will need for sure. I wouldn't put much emphasis on output either, few speakers need more than 150 wpc to shine, and LSI's are fairly efficient. Even my Usher BE-718's, which were admittedly horribly inefficient only really needed 150-200 wpc. So look more so to quality of power than amount with the LSI series. Wyred makes great products, but I do believe their amplifiers are Class D, so make sure this is something you want, the general consensus I've read and my own experience suggests Class A and AB have advantages in sound quality, but D is continually improving and has a major advantage in efficiency, thus far less heat output and no need for bulky heat sinks that make up a majority of an amp's weight.
    As for the Wyred4Sound DAC2 I own one and can't say I could find better for the price I paid. It is fantastic, despite some minor compatibility issues on my computer with USB out, and what is especially nice is that it has a built in preamp stage. Wyred's preamp is done very well, eliminating the need to purchase a dedicated 2 channel pre, which can save you quite a bit. I run it straight to my MC352
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • footwedge
    edited May 2011
    Thanks Reno and Sm88.
    Sm88,
    I'm about to show my ignorance when it comes to electronics but here I go. So is the dac2 used for 2 channel audio only? and I will still need to get a pre for video/HT?
    I thought the amp might be a little much. I will look at the mc mini 7@ 360wpc-4ohms.
    Reno, yes the oppo is on the short list, but at this time I have no idea which one.
  • sm88
    sm88 Posts: 353
    edited May 2011
    Standalone DAC devices are typically two channel, used with a CD player or now through a computer's digital output. For home theater you need what is referred to as a Processor, which has DAC's for each and every channel built in and decodes home theater formats to provide the additional signals. You can think of a processor as a receiver minus the amp and sometimes tuner. They typically have switching features, they act as preamps be they 2 channel or HT, and often have tone control / bass management built in.
    The Wyred4Sound DAC2 is going to beat the sound quality of any reasonably priced processor when it comes to 2 channel audio, but no, despite having 8 channel chips it is not capable of doing more than stereo. What it does have, however, is an HT bypass. This way you can use it as a 2 channel DAC / Preamp but then bypass the signal for Home Theater over to a processor.
    If home theater is your goal, skip the Wyred and get a processor. A good one should do a relatively good job at stereo will providing heaps of features.
    I've owned the following:
    Outlaw 950
    Cheap, but I did not care for the sound it produces - seemed harsh. Lots of features for the money! ~$150-200
    Anthem AVM20
    Feature packed, good two channel and great HT processing, not to bad on price either; a solid unit. ~$400-500
    Anthem AVM30
    Very similar to the AVM20 but with extra bass management and a better setup, loved it but got away from HT. ~$500-700
    Rotel RSP-1068
    Worked well for my needs at the time but was six channel and not seven, not that many movies actually have discrete seven channel sound but feature wise this was still a letdown. Sounded better than the Outlaw but I found the Anthem more intuitive, feature rich, and of at least as high quality sound. ~$300-400
    McIntosh C39
    Fantastic sound quality, warm and silky smooth, but this is a mid 90's processor and was limited to the original HT formats. The preamp section was fantastic and borrowed from their strict stereo preamps, which lends to it's excellent tone. ~$700-800, sold mine to a Polkie actually!
    Parasound P/SP 1500
    Didn't much care for the operation but the sound quality was a step up from the Outlaw. Required a special DAC module and cable to run multi channel formats, which is a pain, but I have been impressed with plenty of Parasound products and think their newer processors might be worth looking into, compare them vs Rotel
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • footwedge
    edited May 2011
    Sm88, thanks for the simplistic description of the different components.
    I would say my listening preference is 70% music and 30% movies. I have a lot music stored on apple devices and would like to be able to play them on a quality system. I believe the dac2 will allow me to connect the ipod or ipad directly for playback.
    As for the HT bypass, does this mean instead of stereo which I prefer, I can bypass and have the music played in 5.1?
    Is a processor and preamp the same thing with both sending signals to the amp? Also, with the dac2 handling 2 channel duties, is there a processor strictly for HT? I don't want to have 2 means (a waste of $) of listening to stereo.
  • sm88
    sm88 Posts: 353
    edited May 2011
    The DAC2 will not allow you to connect an ipod directly, Ipods either go through that USB cable which requires a software installation on your computer, or through the headphone jack. The headphone out on an ipod is analog - it uses the tiny cheap DAC's that are built into the ipod to convert the mp3 files to music. You'll need some sort of ipod dock or to run it from your computer to use it that way.
    The bypass is one of the input settings, when you switch it to bypass, it "passes" the signal through the system so that instead of going to the two channel route, it continues on to your processor where a 5.1 signal can be processed. I've never tried it but it should work.
    Processors are also almost always preamps, you only need one or the other. The processor will have a built in volume control, as well as input switching and everything else. Even video switching. Processors also always offer 2 channel in addition to the extra. I'd suggest starting with a good processor and if you are unsatisfied with the 2 channel performance then considering making the upgrade to the Wyred. I don't think you'll be unsatisfied with it though, you could even find a processor with the same DAC chip built into it, though obviously the implementations of the circuitry do vary between units.
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2011
    I'm with the b&k crowd!have had a few of their processors and found them superior to anything in their price range! But dump the closed cab. You are aware of "heat concerns" don't try to adjust for the heat. Eliminate it by changing to open rack in the first place!! One less prob. You need. To deal with. If you buy a good class a amp they may run warm when taxed but they are spose to. Just the price you pay for high current! This is a good thing, they dissipate heat.by design don't close them in! Plus when in an open rack you get to enjoy looking at them!!!!! Lots-o-luck!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
