pixel tune up for plasma
scottyboy76
do any of the devices or software for restoring plasma images work?
I seem to have some bluish discoloration on the sides of the screen when a mostly white image is on.Where the dark bars are on each side of the picture when cropped horizontally, there appears to be a slight pixel darkening.
I have seen both hardware to hook to the vga port, as well as software to repair pixels.
Any experiences, positive or negative.
humpty dumpty was pushed
Post edited by scottyboy76 on
There is some free stuff out there to try. Here ya go
http://www.jscreenfix.com/basic.php
Burn the image to DVD using ImageBurn or some other software. It should loop during playback so let it run and see how it works.
Link to downloads under Burnable DVD NTSC
http://www.jscreenfix.com/video.phpShoot the jumper.....................BALLIN.............!!!!!
Eliminates Stuck Pixels - Reduces Effects of Plasma Burn ... “I received the Pixel Tuneup this week. It was easy to install on my television.
