Parasound HCA 1200 mods
muncybob
muncybob Posts: 3,228
edited May 2011 in 2 Channel Audio
I've been looking for a used amp to mate with my SDA 2B's....I only understand some of what has been done to this amp...are the below mods considered an upgrade to the stck amp?:
List of Modifications:
* WBT NextGen copper binding posts, RCA inputs
* MJL21193 & MJL21194 output devices--they are MATCHED!
* Gen 1 Sonicaps used throughout
* Voltage amplification stage FULLY REGULATED
* MUR series Ultra fast diodes replaced original bridge rectifiers
* Sand-filled resistors replaced with metal film resistors
* DC servo circuit upgraded
* cryogenically treated 6-9's copper wire used within
List of Disabled Features:
* level controls removed (sounds better without them)
* bridge mode disabled
* loop output jacks removed
I have no intention of bridging or using the loop outputs on the stock amp so these are of no concern to me. The concern I have with older amps is possibly needing to do some work due to old caps, etc. and I'm not able to perform that work...seems this one would possibly be the way to go?
Yep, my name really is Bob.
Post edited by muncybob on
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    Yes.
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2011
    I'd like to have the level controls and bridged mode switch by-passed as well on my HCA-1500A. I do want to keep the looped outputs in case I ever do attempt to integrate a sub again.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited May 2011
    muncybob wrote: »
    I saw this ad on Audiogon. Looks like a solid amp. Those are huge upgrades.
  • muncybob
    edited May 2011
    I made a mistake though, it's a HCA 1000 and not 1200. Did find a another 1000 model with apprx 60 hours on it...I'm thinking these upgrades are worth the extra 100 bucks?
    and now I see a NAD in our FS section priced in same ballpark....decisions...decisions.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2011
    Don't know what the price is,but these upgrades change unit quite a bit. Definitly won't sound the same--good or bad. Is up to the listener!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited May 2011
    muncybob wrote: »
    i'm looking at both of those too, you better make a decision quick! :tongue:
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
