Macbook Optical Port
thetawave2
Has anyone had any experience with the 3.5mm optical port built into Macbooks?
My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Post edited by thetawave2 on
I use the optical out port on my MacBook Pro for playing DVDs with 5.1 surround and iTunes playback. I use a Toslink — Toslink mini-plug cable to my AVR. It works quite well.5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
I use the optical out port on my MacBook Pro all the time. I bought a toslink cable from newegg. I love the sound.
When I had my MacBook Pro, I used this cable from Monoprice.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022902&p_id=1557&seq=1&format=2// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
Dito on that, use the same thing for my Mac Mini which has the same outlet as the MacBook.Main Setup
Fronts - Energy RC-50's
Center - Energy RC-LCR
Rear - Energy RC-R's
Subs - Gone...
AVR - Pioneer SC-37
Blu-Ray - Sony BDP-S360
TV - Vizio E550I-B2
Media Server - Mac Mini -
I prefer the USB output. I didn't really care for sound quality the 3.5mm output, it sounds a bit hollow to me. On another note I'm wondering if I can find additional improvements using a better USB cable such as a Wireworld or similar?
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut -
You mean with an external soundcard?My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers -
You think the optical out sounds hollow?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
No external soundcard.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
I use a basic USB cable from my mac to my V-Link SPDIF converter. Coaxial out to my dac. I'm in the process of upgrading my usb and coaxial cables once I narrow down a few options. I hope i'm answering your question?
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
That sounds really cool but I don't think I'm in the market for peripherals like that just yetMy Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Just got my cable. It does sound a bit hollow, but using the iTunes equalizer helps quite a bit with that.
Works like a charm with my DVD player though!My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers -
I use the optical out to stream music from iTunes on Macbook Pro through Airport Express to the Pre/Pro. One thing I noticed, it will expose not so optimal MP3 songs very much so. However, on decent bit-rate (256+) songs, they are not bad at all.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I currently use the 3.5mm optical out on my Mac Mini to my Onkyo 5508 processor. I think it sounds pretty good and not hollow. However, I do plan on getting an external DAC and using USB out instead so I can get support for higher resolution audio files (24/192kHz). The optical can only support 24/96kHz and lower AFAIK.
I definitely got what bklynNupe was saying. Did a bit of critical listening with a friend last night. For more information check out my blog at paugustinos.blogspot.com!My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
