Help: HVAC expert!
doggie750
Hello polks, need to remove the house AC from outside and reinstall it to my mom's hbouse. I did my prelimenary study & all I need to do is to discharge the freon from the house & back to the compressor, shut the outlet valve & turn on the unit. Once all the freon are in the AC, shut off the inlet valve & cut the pipes & torch sealed them. Please advice if this is correct.
As far the reinstall, I'll check back in once the initial stage is completed.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Dang, running out of time here at work, but:
What size/make/model unit is your condensing unit (outside) ?
Does it have a receiver (probably not) ?
If you can pump the system down into a receiver, and isolate the compressor from the lines, those lines will still contain some charge.
EPA says okay to lose a LITTLE charge ('deminimus"), but that'd be a little more than 'deminimus'.
But, to be honest .... I wouldn't give a crap about that, as long as you don't have any anal neighbors.Sal Palooza -
unfortunately I don't have a pump
. my approach should be ok? Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
The unit has been unplugged w/o any issue, no leaks!Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
I hope no one from the EPA is reading this. If they are, say hello to a $10,000+ fine.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
The EPA doesn't know about this.
.....yet. Just figured out a way to finance some new LSiM 707's. Some sacrifices will have to be made, but .... not by me. :eek:
Meant to get back to this thread, and got side-tracked (as usual).
Looks like you're doing well so far, but I was wondering what freon is in the unit ?
Is it an older R22, or a newer 404a, or ?
Just wondering. There may be a SLIGHT chance that there was some MINIMAL charge lost during your operation.
If so, that'll need to be replaced.
You're not at the installation stage yet, but you will need a vacuum pump and probably need to sweat some access fittings onto the system.Sal Palooza
