Dynavector P-75 modded w/Russ andrews PS
george daniel
Okay,, this is a modded P-75,,upgraded caps(Nichon-Muse),,Vampire PCB RCA's,,in a Hammond aluminum box,,it also comes with Russ Andrews aftermarket power supply,,the standard power supply,,manual/instructuions--all of the jumpers.By switching/moving the jumpers,which is a simple task,you can set this phono for most cartridges,,MC and MM--it also has the PE(phono enhancer mode designed by Dr. T).This is a dead quiet ss phono pre,the Russ andrews PS accepts the power cord of your choice,and the "umbilical" is Kimber Cable -they don't stay too long on A'gon--so -please pm me if innarested. 350.00 shipped CONUS.
Post edited by george daniel on
Okay,,I'll admit it,,it's not the prettiest kid on the block,but, this ain't your usual P-75--it will run with most phono stages in the 1000 dollar range all day--don't let it's small size fool you,,it will work with moving coils and moving magnet carts. I'll let it go for 325.,, shipped and it is dead quiet.JC approves....he told me so. (F-1 nut)
as requested--rca and power connectionsJC approves....he told me so. (F-1 nut)
George, how would you say this stacks up against the Jolida? I think it's the JD-9 Jerry had but don't hold me to it.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Tom,,I may take some heat,, but,,in my system, this was better sounding to me than the Jolida with upgraded tubes,,and my old NYAL modded Super it.It was paired with a dyna xl 20 moving coil cart,, then a Denon 103r,, and it(the dyna) just sounded better to me,the are so many settings for cartridges,,mc/mm.. loading,gain,etc,it also features the "enhanced" mode,which was specifically designed for dyna carts',,all said,,it's a pretty versitle little phono pre..One thing for sure--it is dead quiet.The retail on it,when new was about 700 dollars So,,to answer your question;yep,I prefer the little Dyna vs the Jolida.JC approves....he told me so. (F-1 nut) -
well if not already gone I'll take it. PM sent.
pm received--I think that you are going to be very surprised.Let me know what cart you are using and I'll set it up for your particular cart if you like.
Thank you kindly--georgeJC approves....he told me so. (F-1 nut)
