Moon Audio DH LABS D-75 Modded digital coax 2ft
fbm211
fbm211 Posts: 1,488
HI.
I have gone to AES/EBU cables so I no longer need my D-75 DH labs coax cable.It has been upgraded by Drew at moon audio with Cardas GRCM silver rhodium plated RCAs.
Asking-$35.00 shipped
From moon audio site>>>The D-75 is a precision 75 ohm coaxial digital cable designed for accurate handling of digital audio signals. The most common use for this cable is to connect the digital output of a CD transport/DVD player to an outboard Digital to Analog converter or other digital processor. Several features of this cable make it superior for both digital audio and video use. A solid silver-coated center conductor is used to maintain the most uniform impedance. This minimizes signal reflections, which is very important in digital data cables. The center conductor is encased in a foam Teflon dielectric, which has an extremely low dielectric constant of under 1.4. This provides the lowest dielectric absorption and loss. Noise rejection is maximized by a 2 Layer shield. This dual shield provides 100% coverage for complete immunity to noise. The combination of a 100% aluminum Mylar shield and a heavy braid keeps ground resistance as low as possible. The RCA connectors are Cardas GRCM silver rhodium plating. They are soldered to the D-75 cable using WBT 4% silver-content solder and then the connector is treated with Caig Labs ProGold Conditioning Treatment to keep the gold from oxidizing and providing the best contact possible.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Conradicles
    Conradicles Posts: 6,372
    edited May 2011
    Any crazy chance this is still for sale? If so I'll take it...
  • fbm211
    fbm211 Posts: 1,488
    edited May 2011
    Sorry no.It sold a-long time ago.
    But I can build you one.It will cost more though.
