No Sound FL & FR: Need Help Diagnosing
aaronleong
aaronleong Posts: 1
Hi y'all. I'm new here and just bought a pair of Polk Monitor 60 II towers, and a Polk CS1 Center, all powered by my Yamaha RX-V365 receiver. This will be a 3.1 (currently sans sub). I have an HTPC coming through as my sources.
Moved to a new house Saturday, wired up the speakers yesterday with 16 gauges, and fired up a movie via the PC, and only the center had audio. FL and FR had no signal. I ran the tone test using the receiver, but nothing. the V365 provides both banana plug-ins and push-in/spring-lock connectors for the fronts, and I tried them both, but still nothing; the center is connected via push-in. I know it doesn't matter which set of +/- posts I use on the towers, but I tried connecting to one or the other. I also ensured that the receiver was setup for 3-speaker output (previously it was running 5-speakers).
Not sure what I'm doing wrong. I packed away the Yamaha manual and am still in the process of finding it.
Post edited by aaronleong on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    Mess around with your surround settings and see if that works.
    Your receiver might also have an A/B speaker selector switch....make sure the correct set is enabled.
    Btw, welcome to the forum!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    treitz3 Posts: 20,019
    edited May 2011
    Damned double post. Look down one post.
    edited May 2011
    ^^^Try these suggestions first. ^^^
    Welcome to the forum. Let us know if you make any headway.
  • thsmith
    thsmith Posts: 6,082
    edited May 2011
    Do the above but if it was working before the settings should have been saved.
    I had my center channel go out last week and found the speaker cables and banana connecters were loose.
