PA1200.1 Issues
jasonkelly
Hey guys I was wondering if you might be able to help me out with an issue I'm having. I've got my amp (pa1200.1) wired up to two sr124-dvc subs taking it down to 1 ohm. I was playin around with them and I got them going pretty good. All of a sudden the sound cut out. Now the LED on the side is not red, but it does have a reddish tint to it making it more of a yellow than green. voltage across the speaker terminals is essentially 0 volts. Any thoughts?
Post edited by jasonkelly on
How long did you have those subs hooked up to the amp?
Is wiring correct?? Power/groud? Fuse? speaker wires for 1ohm?
Did you buy it brand new? warranty?2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
theyve been hooked up for a few months. wiring is all correct
Whats your gain set at? My amp's lights look yellowish too. Dont think thats the problem. Im wondering if youve got your gain set too high, youve fried your subs.
Do you have another sub or speaker you can hook the amp up to real quick just to make sure its still playing or not?polkaudio sound quality competitor since 2005
I don't think it's likely he's fried his subs because his amp is only 1200W, and each SR124 has an RMS of 700 and should be able to withstand any clipping longer than his amp.
Its a 4 month old thread and I'm sure the problem is worked out by now. Meanwhile, you're wrong.
nstillmatic wrote: »I don't think it's likely he's fried his subs because his amp is only 1200W, and each SR124 has an RMS of 700 and should be able to withstand any clipping longer than his amp.
Common misconception. You're more likely to fry your subs with too little power than too much. More power is better - it can control the subs better without clipping. When you clip/square wave a sub, it extends the voice coil out and it doesn't move, which means there is no air moving, causing the voice coil to overheat and blow.
What it sounds like however is the amp has blown a mosfet or something.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Def sounds like a blown amp. Is that amp 1 ohm stable?Shoot the jumper.....................BALLIN.............!!!!!
Yes the amp is 1 ohm stable.
Most likely a case of blown subs due to running gains too high. -
The only thing that blows speakers aside from physical damage like stabbing a screwdriver thru the cone is overpowering.
You either build up more heat in the voice coil than it can dissipate or you push the suspension beyond its limits. Too little power will never hurt a speaker.
Why people think this is because they stick a 50 watt amp on a 100 watt speaker, want more volume so they turn the volume up too much and the amp clips which sends out a signal limited only by the input voltage so that 50 watt amp sends out 130 watts or so which thus fries that 100 watt speaker.polkaudio sound quality competitor since 2005
True that...If you are in the neighborhood of the RMS you will be fine. If you are ported use the subsonic filter.
