Blown Parasound
carwashguy
carwashguy Posts: 131
edited January 2012 in Electronics
I have a new Parasound 5250 that has lost two channels in two months. The first time it lost the first channel (closed fuse), this time the second. It is very difficult to un-install this beast and my nearest "authorized" service center is 300 miles away. does anyone have experience with these amps? Am I doing something wrong to keep losing channels like this? Any help is appreciated.
Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Monster HTPS 7000 MKII
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma
Post edited by carwashguy on
  • stubby
    stubby Posts: 723
    edited April 2011
    When you say it is difficult to "uninstall" the amp, is it due to all the wiring or because it is in tight quarters? If it is in a cramped location you could have an issue with heat. Those LSi's are 4 ohms and will put a helluva strain on an amp.
    I believe there is an authorised dealer (Parasound and Polk) in OK City. They should be able to help you out. Good luck!
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • carwashguy
    edited April 2011
    It is just a pain in the neck to pull it out of it's rack and lug it around, think it weighs in the 80 lb range. Sadly the nearest authorized repair center is in Kansas City. Heat is not the issue, has lots of breathing room.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • EUSORO
    EUSORO Posts: 16
    edited April 2011
    Do not mess with the amp and call Parasound sounds like it's fairly new (warranty). Tony or Richard (Parasound president) will be more than happy to assist your issue... They are very accessible. The 5250 should give you 380+ watts 4ohms.. Should have "0" issues running your LSi's.
    Onkyo NR-3007
    Carver M-4.0t
    Parasound HCA 1200MKII
    Parasound HCA 2205A
    RTI-A9
    Csi-A6
    Tsi-100 (Highs)
    M5 (Rear)
    Rti6(Surrounds)
    RT7(Wides)
    Oppo DV-981HD
    PS3
    X360
    Klipsch Sub12
    Klipsch Sub10
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2011
    If you send a mail to the support email address on the Parasound site, Richard himself will reply. I was lucky when my HCA2200ii went out (twice) as Parasound HQ is 20 minutes away from me. So I just took it in to Tony personally - but they'll help you - very responsive / accessible folks as EUSORO mentioned.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • carwashguy
    edited April 2011
    Have any of you guys experienced this problem of the channels dropping off? Two in two months is a bit much, I mean this is a $2800 amp.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2011
    On a new amp? No. I had an issue w/ one of my channels cutting out on an HCA-2200ii, but that was an 18 year old amp. They ended up replacing the output relays and adjusting the bias.
    Otherwise, I haven't had any issues w/ the Parasound amps in my sig.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • carwashguy
    edited April 2011
    After some initial hesitation Tony said he would pay for shipping both ways, even threw in an original box (mine came without), that is a stand-up company. Still isn't two channels in two months a bit much?
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • EUSORO
    EUSORO Posts: 16
    edited April 2011
    carwashguy wrote: »
    I understand the frustration but you might as well get it checked out by the manufacturers. If after all you still have issues with the amp maybe u just bought a lemon. It happens to he best of us. At least you still have a warranty, it certainly could have been worse (no warranty)... Keep us posted
    Onkyo NR-3007
    Carver M-4.0t
    Parasound HCA 2205A
    RTI-A9
    Csi-A6
    Tsi-100 (Highs)
    M5 (Rear)
    Rti6(Surrounds)
    RT7(Wides)
    Oppo DV-981HD
    PS3
    X360
    Klipsch Sub12
    Klipsch Sub10
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    Do you have it installed in a tight cabinet? Perhaps the heat is too much and your frying it? Two channels in a couple months seems extreme for a nice piece like this.
    I've had a B&K 5 channel for over 15 years and never had it in for service(knock on wood) but it is well ventilated. Since you said it was such a pain to remove, my first thought was a tight cabinet.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • carwashguy
    edited April 2011
    No heat is not the issue (don't think), it sits in an open framed stereo component rack. The house is 68 degrees year round, so it is pretty cool. The pain to move comes in when you try to lift this 85 lb behemoth out of the stereo rack, I am telling you it is HEAVY! Just got a pair of 1000w W4S mono-blocks, maybe that will take some of the heavy lifting off the Parasound.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • Beta
    Beta Posts: 267
    edited April 2011
    I had problems with a Halo A21. I had it serviced by an authorized tech. Got it home and the problem continued. Turned out I had a "heat" issue (not saying you do). I purchased a Parasound Zbreeze fan and that solved my problem. Never had another issue since.
    Not surprised to hear Parasound is going to make things right. Like Polk, Parasound has outstanding customer service.
  • DenDeXTeR51
    DenDeXTeR51 Posts: 1
    edited January 2012
    Hi!
    I also have 5508 and 5250(surround speakers) and 2xA23(bridged for front speakers).
    If I want to hear anything, i have to set onkyo volume to -20 - -10dbm, but as I understand this value near the limit of Onkyo =(
    If I set my surround/center channels to +6db in onkyo(Speaker Configuration) I have some kind of clipping =(
    How do you set-up your Onkyo??
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited January 2012
    I've been watching this thread and there seems to be a definitive problem w/ design,make ,quality.This as got to be at least the 3rd report of a Parasound that either overheats, shuts down protection style or just doesnot come back.As far as looks go and only looks it's a beautifully milled amp but then I viisted the EMOTIVA SITE W/ THE XP-2 AMP AND NOW THERE'S A SITE TO BEHOLD .i KNOWIT'S AN ADVERTISEMENT BUT IT'S SLICK AND IF BACKED UP AND i HAD TO DUMP MY ADCOM555 THIS IS THE SS AMP i WOULD GO FOR AT $800.@300W A SIDE.any devisiveness here?
  • Tankman
    Tankman Posts: 419
    edited January 2012
    I have found some review's on B&K amp's and other's too with dropout's..It happen's.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2012
    Really? From watching this thread, that had no posts for 9 months? Maybe you're looking too hard.
    I had a Parasound amp fail once, it was 16 years old at the time, and required 70 cents in parts to fix. It's run another 7 years so far without further issues.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2012
    From 4 years ago . . .
    http://www.parasound.com/pdfs/5250Upgrade.pdf
    This series is not as robust as the HCA, Halo, and JC lines.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    I've had 2 fail - an HCA-2200ii and an HCA-1000A. But they were also older amps - so I wasn't surprised. But my 2250, 2125, and A21 never gave me any issues. And Parasound's support is above and beyond as mentioned. I took the 2200ii in twice (I live near HQ) and after the 2nd time, they offered to sell me a new A21 minus what I paid for the 2200ii. All I had asked them was what should I do? The fact that Richard himself answers many of the support mails is awesome as well.
    My HCA1000a is still sitting in the living room - it just turns on but doesn't do anything - when I get a chance, I will get them to repair it.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • WilliamM2
    edited January 2012
    The amp in this post was new in 2011, and it seems the issue was corrected in 2008. Doesn't seem all that widespread either:
    There are only six reports of such Model 5250 failures and in
    each case the Model 5250 was installed, contrary to our instructions, in an unventilated
    cabinet with no provision for trapped hot air to escape.
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    That'll kill any amp. My cousin has a NAD T955 in the media 'cubby' he built when remodeling his HT. He left the doors closed and the amp and one channel fried within a month. Lesson learned, but some of these issues are user errors I'm sure..
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
