cracked rubber on woofer MW 6503 Monitor 10
Greg H
Greg H Posts: 16
edited April 2011 in Vintage Speakers
Any way to repair cracked rubber that surrounds the MW6503 Woofer for My Monitor 10? Maybe Silicone?
Also, would it be wrong to replace it with a MW6502 from a 5jr?
Post edited by Greg H on
  • wayne3burk
    wayne3burk Posts: 939
    edited April 2011
    i'd try black electrical tape
    i'm just sayin
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • Greg H
    Greg H Posts: 16
    edited April 2011
    It is a smail v-shaped nick about 1/8". Nothing Major.
  • Greg H
    Greg H Posts: 16
    edited April 2011
    How about MW6503. Can I replace it with the MW6500 or MW6502?
    Toolfan66 Posts: 18,023
    edited April 2011
    Gasket silicon from a autoparts store will fix i and keep it air tight.. Put it in from the back side that way it won't look to bad..
  • brgman
    brgman Posts: 2,859
    edited April 2011
    MW6503's are not hard to find.Just get the right one for about $30-35 and call it a day.
    Post in the wanted area unless someone steps up here.
    I’M OFFENDED!!!!
  • Greg H
    Greg H Posts: 16
    edited April 2011
  • DON73
    DON73 Posts: 516
    edited April 2011
    They are almost always available on e-bay
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • pdxfj
    pdxfj Posts: 376
    edited April 2011
    Liquid electrical tape works wonders. I've used it on my old Yamaha motorcycle to repair small cracks and pin holes on rubber diaphragms in the carbs. Don't see why it wouldn't work on speakers. :smile:
