My MiniDSP Shipped....
Yes, DSP is off but might come handy later after I build the 190v.2 (something like ED A7-900). Using DSP to eq. the sub was the plan for the sub.
Back to the regularly scheduled miniDSP program.
I am planning on building one or two A7s-450 with the 19Ov.2.
BTW the first release of the XTi's were buggy. The 4000 is commonly known to be a noisy amp. I've really haven't recommended them until the last version/release of them. -
dcmartinpc wrote: »I am trying to figure out why there are 3 different versions of the 2x4 software. It seems the advanced pretty much does everything except sum the stereo ins for sub outs. I guess the 2.1 does that, but It just seems to me, add that one feature to the advanced and they only need 1 plugin...
Don
Either the Advance 2.1 or the 2.0 will work for sub only duties. I haven't had time to sit down and go through all the permutations of plug-in's they offer. -
Yes they were. But they released a firmware update that fixed it. There was also a faulty control board in the front of the unit that they will send a free replacement for. That fixes all of the issues I known of with the amps, including the random drop outs.
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
