Newb tube amp
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited April 2011
    What are your initial impressions of the amp?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited April 2011
    I can tell that the lows and mids are more subtle than my carever. i do agree with the others that the highs are lacking. Made me question if the ML's were having a problem.
    I can also tell that tubes do produce a much more powerful output than my carver with lower volume.
    However I will be looking into better tube to try to fix this. Recommendations would be nice, I am looking at the set that was recommended on the first page.
    Also will add that the "excitement factor" is with me right now with having a new toy in my system. So I will need a few days to settle down.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • michaeljhsda2
    edited April 2011
    As suggested I would try a different quad of preamp tubes. As far as the power tubes, I would leave those in there IMHO. If you decide you want to change those out keep in mind that you will need to remove the cover on the amp and make sure the bias is set in the proper range. It's kind of a pain to do that and you have to be careful not to let the probes of the MM slip....
    As others have mentioned, the preamp tubes are more than likely the cause of the attenuated highs. I used that amp to power 1.2TL's and 1C's and the highs were not lacking. Synergy is sometimes hard to obtain. Are you ultimately going to use the amp on different speakers?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bigaudiofanatic
    edited April 2011
    A few things as I switch from eagles back to Norah. Norah's highs seem to be more natural and not caped. So could of been the cd's being played.
    The louder the volume the clearer things become. Will have to really try it tomorrow.
    As far as the speakers. I honestly can not say. At this point I have ONE room for everything. So hard to really have two sets of towers especially with the ML's.
    Who knows what I will have in my man cave when I get one. I know I want a dedicated 2 channel setup and a HT setup so who knows.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2011
    Another fine point (and I don't know if yours will be the same), but my tube gear continues to get happier and happier for up to 45 minutes until the transformers are nice and warm. I usually don't even start the source material for 30 minues. Tube gear takes a bit more patience than SS.
    BUT IT IS SOOOOO WORTH IT !!!
    TOOBS RULE
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • michaeljhsda2
    edited April 2011
    The longer it warms up the better it sounds, no doubt about it. You wouldn't think 52 watts would be enough power to drive many speakers but there is just something about a tube amp and how powerful they are.... BTW there are a few hundred hours on both the power tubes and the preamp tubes so the amp is well broken in at this point.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bigaudiofanatic
    edited April 2011
    Sort of noticing that right now.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2011
    Lets have some awesome pics
  • bigaudiofanatic
    edited April 2011
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited April 2011
    Will get some better ones probably tonight.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
