meant to say any1 KNOW OF some good FM tuners/recommendations?
RandyWilliamson
RandyWilliamson Posts: 178
edited April 2011 in Vintage Speakers
I've been putting this off for awhile now...so im looking for good reception and sound. Hopeful this unit will be the cheaper of most of my other stuff.
Thanks all. And hello to everyone I havent been around in awhile but have been enjoying my rig. Looking to add some good radio sounds now.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Post edited by RandyWilliamson on
    mhardy6647 Posts: 35,235
    edited April 2011
    New production or vintage? Solid state or vacuum tube?
    The great bargain in current production by all accounts is the Sony XDR-F1HD, an HD (hybrid digital) tuner. It is inexpensive, very good in "stock" form, and can be upgraded, it is said, to world-class performance (both AF and RF). Less than a C-note for the stock version.
    http://theaudiocritic.com/plog/index.php?op=ViewArticle&articleId=35
    http://theaudiocritic.com/plog/gallery/1/XDR-F1HD.jpg
    upgrades? See Mike Williams' site: http://www.radioxtuners.com/
    Now, if you want to talk vintage things can get interesting...
  • seeclear
    seeclear Posts: 1,244
    edited April 2011
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Conradicles
    Conradicles Posts: 6,377
    edited April 2011
    The Sony XDR-F1HD is a giant killer. Don't sleep on the Denon TU-1500RD either.
  • RandyWilliamson
    edited April 2011
    I'm certainly glad I asked...that Sony looks tough to beat.
    Question these are free over the antenna stations? we don't have to subscribe?
    From what i read it does seem free...the stations are broadcasting in HD...you just need a nifty gadget like this to catch those waves.....my pre-amps a GFP-710 nothing too high end you guys think it'll work well with this type of unit?
    Who can argue with that price? The only downside is the namebrand...:biggrin:
    But a bargain none the less!
    Benq W5000
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited April 2011
    You'll probably be fine with the Sony unit Randy. Being that you're in a well populated area ,I'm sure there are a number of HD radio stations to check out. There's a website to see what HD stations are available around the USA. I use a Sangean unit,it's decent, mainly use it to listen to Dr. Savage in HD-AM in the late afternoon/evenings.
    edited April 2011
    HD radio is free..the only problem is that you should check the area you live in. In mine such a device would be fairly useless as I don't think we even receive '1' HD broadcast. As far as this tuner beating any 'other' FM tuner--that's a bit overdrawn and even in the review itself, the reviewer states that there are a couple of things that the Sony does not do as well as a more traditional FM Tuner.
    Also, the idea that the Internet is the solution to your problem, assumes that you have invested the monies into sound cards, computer DAC units with USB ins, etc. That involves some coin. You can stream directly to an AVR and I do that as well with my PS3 but I don't find that to be a significant improvement over the analog broadcast--maybe that's just me? I certainly do not and cannot, at the moment, feed a decent signal from my laptop into my 'system'. My college station for example, comes in 'much better on a tuner than it does off my laptop'. The problem also includes how good your internet service is--mine is borderline for download speeds. The Digital age is great but it is usually people who have good access and who are 40 or younger who sing the death knell of 'analog' broadcasts--and that's OK because they will eventually be correct. In the meantime, some of us old 'geezers' will still use those archaic devices we call tuners. lol
    As mhardy points out. Don't rule a quality Tuner out. But if you're within 'striking distance of a metropolitan area that Sony HD might be the ticket?
    Good Luck!
    cnh
    edited April 2011
    The Sony HD tuner has very good RF performance. It will receive conventional analog FM as well as HD (although, if memory serves, it automatically switches - one of the modifications is to convert the analog/HD switching to manual). It is, by all accounts, a very good FM tuner by any standards... at its price, it is well-nigh unbelievable.
  • RandyWilliamson
    edited April 2011
    Yea im ready to buy...just can't find one in stock!!
    Benq W5000
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited April 2011
    Damn, that sounded good enough I was sold on one too. Of course the marketing geniuses at Sony discontinued it. (You can still buy plenty of 300 disc CD changers from them of course.) Anyway, here's one on the 'Gon. http://www.audiogon.com/cgi-bin/cls.pl?misctunr&1306982617&/Sony-xdr-f1hd-new-in-box
    Hard to shell out $200 when you know they sold for $50 after rebate a year ago. :frown:
    edited April 2011
    They did?!? Crap, I'm sorry... I had no idea.
    pitdogg2 Posts: 27,319
    edited April 2011
    yep I believe they were 99.00 but had a rebate if I'm correct. At 200.00 you're close to some of the cheaper Sansui's or Kenwoods.
  • On3s&Z3r0s
    edited April 2011
    Makes me wish I was paying attention to tuners a year ago. Damn my NAD receiver with its good-enough tuner section! :biggrin: If the Sony's as good as everyone says it could be worth twice retail for one of the last new ones (assuming it really is unused) you're likely to come across. Somebody else needs to buy it before I succumb to temptation.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2011
    I've had great luck with a Sansui TU-417, TU-717, TU-917 and TU-919, a Kenwood KT-9300 and KT-5020, NAD 4155, Crown FM Two, Onkyo T-9090 and Fisher KM-60.
    I won't be bashful either. I have 2 nice units for sale in the Classifieds right now. The Onkyo is probably better by a percentage point.
    http://www.polkaudio.com/forums/showthread.php?t=118571
    http://www.polkaudio.com/forums/showthread.php?t=118643
    Someone above mentioned these (Thanks!) and I will work with you if we are reasonably close on price.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
