Anyone have some good AM/FM receivers?
RandyWilliamson
RandyWilliamson Posts: 178
edited April 2011 in Vintage Speakers
I've been putting this off for some time now.....but I think this would be on the cheap side compared to all other things I've previously bought.
So I guess im looking for something that gets good reception.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Post edited by RandyWilliamson on
    edited April 2011
    inspiredsports has two Tuners for sale here..both look good!
    http://www.polkaudio.com/forums/showthread.php?t=118643
    http://www.polkaudio.com/forums/showthread.php?t=118571
    Take a look!
    cnh
    treitz3 Posts: 20,119
    edited April 2011
    Randy, I hate to say this. I really do, but FM/AM is an outdated product. You can get the same quality [sometimes much better] by going online and adding it from your computer or rig. It's nothing audiophile, mind you [Neither is FM/AM] but the worldwide stations sure as hell beat the local stations that come and go with the weather and other factors I won't get into right now.
    I can't believe I just said that.
    92.3 out of Greensboro, NC is my favorite for classic rock. Here's a link....
    http://www.rock92.com/pages/3609314.php
    Click onto whichever works for you. Best thing is? No antenna or reception issues....just the station. I hope this helps....
    mhardy6647 Posts: 35,235
    edited April 2011
    Nothing for sale, but in terms of 'affordable' vintage receivers of fine quality and performance (and FWIW), I am a sucker for Yamaha:
    (that's a CR-2020, which did get some use in the living room for a while some years back, mostly with a pair of Allison Ones)
    That said, I would echo the previous post, sort of, and suggest at least considering an integrated amplifier. A Yamaha CA-800, CA-1000, CA-1010, or CA-2010 would be just dandy from my admittedly phenomenally biased perpsective.
    EDIT: oops, you meant tuners! nevermind...
    http://www.polkaudio.com/forums/showthread.php?t=118679
    sorry!
