Carver TFM-35 Issue
renowilliams
renowilliams Posts: 920
edited May 2011 in Electronics
Well my new to me Carver TFM-35 arrived and I unboxed it. Cosmetically it look fine but when I hook it up,no lights come on and it just Humms. I downloaded the manual to ensure all connections were correct and I set it to stereo. I'm thinking a possible fuse problem. Any ideas???
On a positive note my OPPO BDP-93 arrived and it is fabulious.
Any help from you Carver experts would be greatly appriciated.
Tim
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Post edited by renowilliams on
    heiney9 Posts: 25,502
    edited April 2011
    I believe the TFM models have a commutator that swings from the low voltage rail to the high voltage rail and they are known to get stuck. Sounds like you'll need to send it to someone who knows how to fix it.
    This is just a guess based on what I've read over the years at various sites like DIYAUDIO. Bad fuses don't cause hums.
  • renowilliams
    edited April 2011
    Thanks for the reply Heiney 9. Well thats a bummer. I live in Canada so shipping this thing to the US is out of the Question would cost too much. I wonder if there is a Authorized Carver repair depot in this country. I may just buy a brand new amp and say the hell with it.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    treitz3 Posts: 20,119
    edited April 2011
    Hang loose. I'll find a list of repair shops for you in Canada.
    edited April 2011
    Here you go. For your knowledge, there are no authorized shops in the world to work on Carver equipment. The company is defunct. That said, be sure to send it to a reputable service shop, otherwise you may end up with an expensive door stop. The ones below have been recommended by Carver gear users for repair in Canada. Unfortunately, this is all the information we have on them at the time. Good luck and please get back to us!
    Ontario, Canada
    Rick Turcic
    Ontario Audio/Video Service Inc.
    2074 Steeles Avenue East, Unit 21
    Brampton,Ont. Canada L6T 4Z9
    905-791-2020 fax 905-791-2121 Tf 888-791-2899
    rick@ontav.com Ontario Audio/Video Service Inc. (open 8-7 Mon-Thurs., 8-6 Fri., 9-2 Sat.)
    Ontario, Canada
    Chris Bridge who is
    anatech from http://www.canuckaudiomart.com
    Vancouver, Canada
    Columbus Radio
    359 Lynn Ave
    North Vancouver BC, V7J 2C4
    604-985-8824
    edited April 2011
    Chris Bridge (anatech) from DIYAUDIO, is a stand-up guy. I've had many conversations with him on the DIYAUDIO forum over the years and at one point I was going to send my Adcom to him to refresh but it was just to expensive to ship up and back.
    I would recommend him without hesitation as he knows his stuff. Adcom/Carver/Nakamichi, etc are his Forte.
  • renowilliams
    edited April 2011
    Thanks very much H9 and Treitz3,I apprieciate your help. This week-end I'll do some more troubleshooting and if I have no luck,I'll give one of those guys a call.
    Thanks again
    Tim
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    edited April 2011
    No problem, Tim. Keep us posted and best wishes to a great end result.
  • renowilliams
    edited April 2011
    Well I opened up the Amplifier and took some pics. Nothing looks loose or obvious with the exception of the board looking a little burnt near resisters R281 through R284 on picture DCS00266.
    Here are the pics;
    http://www.flickr.com/photos/renowilliams/
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2011
    Here's another Canadian Carver tech who really knows his stuff; I HIGHLY recommend him:
    Robert Galayda
    email: mids@shaw.ca
    eBay ID: musinteg
    Don't have his phone number as I lost it with my last phone~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    edited April 2011
    Lasareath wrote: »
    is that the thing I hear when I turn mine on. It sounds like someone is inside the case and hitting the cover with a hammer.
    I doubt it, simply put a commutator is a switch. There is no physical part moving around inside the amplifier that could hit the cover.
    edited April 2011
    Lasareath wrote: »
    Some Carver amplifiers will do this. It's completely normal and as you know it only happens upon powering up, Sal.
  • renowilliams
    edited April 2011
    Well guys, I played with my Carver TFM-35 today and got it working. I had to move the input connectors and it came to life. When I adjust the gain control knob it cuts in and out. Anyway, I'm going to send it in and have an expert go over it.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited April 2011
    It may just need the gain pot cleaned. Try some Caig's on it. Clean the bridge/stereo switch, too.
    edited April 2011
    Agreed, Polkersince85.
    You might want to save some money and just clean the pot, as this sounds like the culprit. It would be a $15 repair and if you have Radio Shack's up there, you could have it repaired today and it would last you until a major problem reared its ugly head.
    This Caig De-Oxit also works to provide better contact which means better sound, so I wouldn't be surprised at all if the amplifier sounds better after the repair if you take the time to clean all of the physical contact points.
    Now keep in mind, these amplifiers are up there in age and will be in need of proper maintenance, including recapping and bringing the unit back up to specifications at some point. That said, if this wasn't a bill you were expecting to pay right now, try the De-Oxit and enjoy the music until you are well prepared to have the unit refurbished.
    If you have not ever used De-Oxit before, just read the instructions or feel free to ask. It's a very easy product to use. Just make sure to power off the gear prior to working on it.
  • George Grand
    George Grand Posts: 12,256
    edited April 2011
    I think the RCA input connectors are a weak area of Carver amps. I've seen your exact problem before, it wasn't cables, and it wasn't a gain or input level controller that got dirty. Crummy input connectors.
  • thsmith
    thsmith Posts: 6,082
    edited April 2011
    +1 GG, I was thinking the same thing. I know an out of spec center pin spring will cause problems.
    I use a RCA connector with the outer barrel broken off to test mine and retention as required.
  • renowilliams
    edited May 2011
    Well I ended up sending my amp to Ontario Audio/Video. I spoke to Rick there today and gave him the green light to do a complete refurb. Will get it in a week or two. I am looking forward to getting it back Rick says it will be better than when it first came from the factory and he will give me a one year warentee.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    edited May 2011
    Hey Tim,
    What did you think of the Carver while you were running it? I'm thinking of picking one up to see what it sounds like? Sorry I missed you the last couple of weekends. My wife has been away and my teenage daughter is shopping for her school trip to Quebec City--she's 13 and I have to drive! She's a good kid but girls that age can be a handful.
    cnh
  • renowilliams
    edited May 2011
    To be honest CNH I never ran it long enough to find out. I decided to shut it off and get it looked at.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
