Newb tube amp
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited April 2011 in The Clubhouse
Looking to get my feet wet in tube amps. Just trying not to spend much but just want to get into it.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • thsmith
    thsmith Posts: 6,082
    edited April 2011
    Anthem AMP 1
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited April 2011
    PM sent
    SDA SRS 2.3TL's
    SDA 2B TL's
  • gdb
    gdb Posts: 6,012
    edited April 2011
    I'm starting with a MF tube buffer hitched to all SS gear, some say, that's all the tubes they need or want. I haven't drawn any conclusions yet about it's place in my set-up. Maybe you might consider a buffer as a first step also, or not.:smile:
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2011
    3 Questions:
    -- How much is not too much?
    -- How good do you want it to sound?
    -- How much do you want to spend on the vacuum tubes themselves?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    Going to put tubes on the Logans? I'd read some threads at MLO before you jump too deeply to get an idea of what works and what don't.
    For example, I tried a pair of 275 MkV's on mine. The mids are to die for but the top end rolls off negating the purpose of the panel. They didn't work well in my room.
    Just a heads up.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • inspiredsports
    edited April 2011
    Hawkeye wrote: »
    Just a heads up.
    Gordon
    I've not had my ears on that particular amp so I don't know it, but my first inclination is to ask if you rolled in any tubes known to have a more revealing top end?
    NAD SS rigs w/mods
    GIK panels
  • Hawkeye
    edited April 2011
    I honestly did not. I had the tubes and the SS here at the same time and my dealer gave me a limited amount of time to decide. Some of the guys who run tubes and ESL's have rolled for years and may have a better response for BAF, that's why I recommended MLO.
    I don't have enough experience to give advice, just point in the right direction on occasion.:redface:
    Gordon
    2 Channel -
  • janmike
    janmike Posts: 6,146
    edited April 2011
    3 Questions:
    Well, one was my first question.
    "How much is not too much?"
    Second question.
    What other gear? Speakers, Pre...
    Michael ;)
    NORTH of 60°
  • bigaudiofanatic
    edited April 2011
    I may run the amp/pre amp on the logans however I have other speakers that I an try it on if it does not work out. I may even take it to work in my office.
    Budget 500 or less, pretty good best "bang for the buck" Not sure about the tubes.
    Honestly one day I hope to have a mcintosh pre amp and amp with a set of ML in a dedicated room.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • inspiredsports
    edited April 2011
    That Anthem Amp 1 is a mighty good recommendation at the $500-$550 price point and you might even get one with a set of tubes that sounds great.
    If not, there are lots of good, affordable 12AU7/ECC82 and EL34 options available.
    You can alway go crazy with a tube budget, but very decent 12AU7's can be had for $20-$25 each, and a quad of brand new and SED (formerly Svetlana) Saint Petersburg Russia EL34's from Jim McShane are about $110. You can retube for even less gently used.
    NAD SS rigs w/mods
    GIK panels
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2011
    I bought a yaqin mc10l from tubstien on ebay for a little over $500 and it killed the top end of my logans but has the best mids and great power
    I may try to get some diff pre tubes in there
  • bigaudiofanatic
    edited April 2011
    What about a Yaqin MC-10L?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Hawkeye
    edited April 2011
    BAF, next time your in Southern MD, give me a call and listen before you set a goal. It may not be what you think it is until you hear it.
    Gordon
    2 Channel -
  • bigaudiofanatic
    edited April 2011
    Just bought one :cool:
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • polkfarmboy
    edited April 2011
    The yaqin is a great tube amp and I hope you love it but for me I am very sad there is no highs because everything is top notch
    When I first put it to work I was in love and could not believe how lively it sounded and all the things I had missed in my logans were jumping out in front of me . I started really getting tired of the complete absence of the highs and only use it occasionally now
    I really hope that I can fix this problem with some new tubes and like the wise gorden said "the top end rolls off negating the purpose of the panel" so for now I really enjoy the tubes with my polk rti8 rather than the ML source
    I
  • inspiredsports
    edited April 2011
    I had a Yaqin CD-1 Tube Buffer that came with the same Chinese 6N1 signal tubes that ship in their MC-10L Amp. I can honestly say that was the worst tube I've ever auditioned, especially when it came to reproducing upper-mids and treble.
    A nice quad of Amperex (Holland) Bugle Boy ECC88/6DJ8's might cost $150 or more, but that will cure what ails the $5 each 6N1's that ship from the factory.
    NAD SS rigs w/mods
    GIK panels
  • bigaudiofanatic
    edited April 2011
    Will have to order them next week.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • polkfarmboy
    edited April 2011
    Thats the best news I have ever heard concerning this amp
    Where would we acquire these tubes from?
  • Hawkeye
    edited April 2011
    I don't mean to imply that tubes "can't" be used on an ESL. From my research and talking to other owners, it is a jagged path to follow to and obtain your desired results.
    I would imagine if you enjoyed rolling tubes and tasting the differences, it could be an enjoyable path to follow.
    Gordon
    2 Channel -
  • polkfarmboy
    edited April 2011
    Hawkeye wrote: »
    Gordon
    Your first post gordon was right on the money about the integrated amp he choose though . The yaqin really does have no highs with the supplied tubes but hopefully I can get a hold of the Amperex holland's and report back on how they improved an otherwise excelent value tube amp
    Not to mention imo its one of the best looking retro style tube amps out there
  • Hawkeye
    edited April 2011
    Gosh, I hate it when somebody agrees with me! It almost makes it seem I know what I'm talking about sometimes!:biggrin::biggrin:
    I do hope you guys figure it out and let us know the results. I'd certainly be interested in hearing about it.
    Gordon
    2 Channel -
  • bigaudiofanatic
    edited April 2011
    So your all saying I threw money away? Or do I just need new tubes?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • polkfarmboy
    edited April 2011
    You have not threw any money away assuming you paid around $550 then you got real value for money.If you hook this up to some cones that may sound a little on the bright side then this tube amp is a blessing . But you have some great speakers and you really want to use the panels full potential and sadly the yaqin's pre amp section just fails to deliver in this department
    The el34 power tubes are excellent and I have read alot about users going back to the originals after rollin them out for different ones so they are good .Despite these probs its still one hell of an amp and you will be in for a treat . Remember this tube amp goes into double digits and the bass and mid has to be heard . If you have never heard tubes then your gona love it and if the pre section get remedied it will be one hell of a sound system
  • inspiredsports
    edited April 2011
    Not at all, but that's why in posts #5 and #17 I tried to point out that it is a slippery slope when you start down the path of attaining better sound.
    Tube amps are highly dependent upon the tubes used, and while Yaqin uses decent components, they try to keep the initial price low and the compromise is they use very inexpensive tubes.
    Even so, the tubes they use from the factory may sound great when paired with your particular sources, preamp, wires and speakers. Synergy between components varies in every situation.
    You should hook it up and listen to it in your specific system for several weeks before even thinking about tubes.
    NAD SS rigs w/mods
    GIK panels
  • bigaudiofanatic
    edited April 2011
    Ok, got home to find my amp waiting for me. Anxiously and cautiously I took it upstairs and slowly unpacked it. The previous owner marked the larger tubes to which slot they go to. Very easily put them in.
    Made all my connections and fired it up and waited as the soft glow of the tubes filled my eyes. "Five min"
    I noticed however one of the larger tubes "forgive the newb" was not glowing. Does this mean I need to replace it "single or as a group" and what and where would I need to look if that is the case.
    Second I started with Norah Joans and ended with Pink Floyd.
    My meter on my monster went down twice during this time from 123 to 116. Was this from the amp?
    Forgive me being a baby as well but do these tubes blow up?
    Thank you in advanced.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • michaeljhsda2
    edited April 2011
    Turn off the amp and unplug it from the wall outlet. After the tube cools off make sure that the tube is seated all the way into the socket. The tube may not be making full contact as the tube glass is barely wide enough to fit through the chassis.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • inspiredsports
    edited April 2011
    The tube that is not glowing needs to be looked at. Turn it off and cool it as above.
    First can you tell me what tube is not glowing? It is a 6N1/ECC88/6DJ8 signal tube, or an EL34 power tube?
    When it is cool, I would remove it and inspect the pins to first make sure they are all there, and then to gently see if anything is loose.
    Also, it's best not to get oil from your hands/fingers on the glass so use thin gloves or a soft cloth like a small piece of an old tee shirt while handling tubes unless your hands are very clean and dry.
    If all of the pins are intact and tight, "reseat" the tube by carefully lining up the pin pattern, pushing in it straight down and then gently wiggling it just a bit while gently pusing down.
    When you power back up, watch closely (with lights low to be sure) and shut it down if it does start to glow as the others power back up. Did you notice I used the word "gently" an awful lot :biggrin:
    NAD SS rigs w/mods
    GIK panels
  • bigaudiofanatic
    edited April 2011
    The tube is now glowing so that is good. After tonights listen I will let it cool and tomorrow will clean the tubes. I only touched the metal on top.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • inspiredsports
    edited April 2011
    This is a fine point, but oil holds heat and can (not always), but can cause hot spots that shorten tube life. Clean glass dissipates best. The top part is still glass with a metallic coating on the INSIDE.
    Also, I'm not familiar enough with that amp to know if the bias has to be set/adjusted, or if it is what they call "self-biasing". If the seller charted which exact tube went in which exact spot you should be OK, but if the pairings aren't exact and the unit requires biasing, you'll need to learn how that is accomplished.
    Some handling is required getting set up, but I've always heard that once you get everything set, just leaving it alone is the best course of action.
    Enjoy!
    NAD SS rigs w/mods
    GIK panels
  • michaeljhsda2
    edited April 2011
    It's really glass on the outside but it does look like metal doesn't it? I believe that is the getter flash that is inside the glass but I'm not certain of that. What speakers are you driving?
    SDA SRS 2.3TL's
    SDA 2B TL's
