Any thoughts on using Canare 4s11 for rewiring SDA's???
nooshinjohn
Just looking for a new use for the Canare 4s11 that was replaced by the (imfamous)MIT EXP-S2's. Would using this wire for building a new harness work well, or is it simply not nessesary to upgrade th einternal wiring.
You can, it's a little heavy though."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
nooshinjohn wrote: »Just looking for a new use for the Canare 4s11 that was replaced by the (imfamous)MIT EXP-S2's. Would using this wire for building a new harness work well, or is it simply not nessesary to upgrade th einternal wiring.
Why not just order more MIT wire and use that :eek:.. lol
Honestly have no idea, never rewired a speaker before but it couldnt hurt I wouldnt think......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
