150`s run in parallel with rt70`s
jimi64
jimi64 Posts: 85
edited February 2004 in Speakers
Was just wondering if anyone has run this combination of speakers.I have mine running this way off an ATI 2505 and the overall sound is much better than either speaker by themselves, to me anyways.This set up is just temporary till I get the12`s.Just hope the 12`s sound better or atleast as good.Would like to hear any comments about this set-up or this vs the 12`s,Thanks Jim
Post edited by jimi64 on
  • dorokusai
    dorokusai Posts: 25,576
    You are creating twice the soundstage, it's a no-brainer. If it sounds "better" than all the "better" :)
    VR3 Posts: 29,398
    i believe..........he's got it
    BTW -- Stacking, running side by side, has yielded great results for me....Another way to get em to sound better is pick up some tri lams (there are 2 on ebay now for 30 dollars BIN, look under Polk tweeters. If you dont like it, you can probally sell it and the baffles it comes with for double, if not triple.....
  • jimi64
    jimi64 Posts: 85
    Yes..I realize it`s a bigger soundstage:) --I should`ve clarafied that this seems to fill the voids where each speaker lacks.They seem to compliment each other in creating a fuller sound from the high`s to the low`s...anyways better is better:) have a great day!
