Phono cartridge suggestions?
Timothy Smith
Timothy Smith Posts: 764
edited April 2011 in 2 Channel Audio
Does anyone have any suggestions on a budget MM phone cartridge?
Can anything decent be had for around $100 or am I fooling myself?
My primary turntable is a Thorens TD-160.
Thanks!
Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
Post edited by Timothy Smith on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2011
    Thanks!
    You could try the Denon DL-110, it is a high output MC - so it can be used on a MM line input.
    It has some good street 'cred - a tad higher than $100 but in the ball park.
  • gdb
    gdb Posts: 6,012
    edited April 2011
    I just got a TD-145 I have been told that a Shure M97xE would be a fantastic low cost MM for the TD 160/145 table. $55.00 delivered, you can't go too far wrong for starting up.
    http://www.amazon.com/gp/product/B00006I5SB/ref=ox_sc_sfl_title_1?ie=UTF8&m=ATVPDKIKX0DER
    This review was written about the M97xE when it was selling for $140:wink:
    http://forum.audiogon.com/cgi-bin/frr.pl?ranlg&1092402094&read&3&4
  • gdb
    gdb Posts: 6,012
    edited April 2011
    I love this quote from the review on A'gon !!!:biggrin:
    (If your speaker cables cost more than your dog's hip replacement surgery, then I'm talkin' to you.)
  • gdb
    gdb Posts: 6,012
    edited April 2011
    http://community.klipsch.com/forums/t/120323.aspx
    check out the third cartoon down:biggrin:
    C. Rodrigues cracks me up with his audio funnies.
    nooshinjohn Posts: 25,878
    edited April 2011
    gdb wrote: »
    What does this have to do with the OP's question? Start your own thread:rolleyes:....
    I second the thoughts about the Denon DL-110. They build a great cartridge for the money There are a couple Sumiko cartridges that can be had for that coun as well. The Needle Doctor out of Minneapolis will be your best place to look.
    John
  • gdb
    gdb Posts: 6,012
    edited April 2011
    What does this have to do with the OP's question? Start your own thread....
    Don't be one of these, John.:wink:
    Pissant is an epithet for an inconsequential, irrelevant, or worthless person, especially one who is irritating or contemptible out of proportion to his or her significance.
  • Libertyc
    Libertyc Posts: 915
    edited April 2011
    Go with link that gdb posted...The Shure M97xE.
  • Face
    Face Posts: 14,340
    edited April 2011
    Another Shure M97xE user here, it's a nice sounding cart for the money.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited April 2011
    strong recommendation to get a Grado cartridge
    It is also made in the USA
    http://www.gradolabs.com/frameset_main.htm
  • gfong
    gfong Posts: 1,079
    edited April 2011
    Do a few searches on the Ortofon 2M Red. nice cart for $99.00. Competes with the Audio Technica 120E and the Shure M97xE.
    All 3 carts listed have different sounds to them. Would be up to you to decide which one you like? The Audio Technica 120E has nice bass and very stable analog sound. 2M Red has nice bass and great highs and can track through tough records.
    I do not know about the Shure as I have not owned one but when I was looking for carts it got mentioned in reviews along with the other 2 I mentioned.
    I have owned the AT and the Ortofon and currently using a Ortofon 2M Blue.
  • Face
    Face Posts: 14,340
    edited April 2011
    The Shure has a warm sound to it.
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    I fondly remember Grado's when I was serious about vinyl but their unshielded motors had a tendancy to interact with some turntables with A/C motors causing hum.
  • Timothy Smith
    edited April 2011
    Thanks man.
    You folks are the best!
    Tim
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2011
    Another vote for the Shure.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • gdb
    gdb Posts: 6,012
    edited April 2011
    Got any extra Thorens headshells for sale?:smile:
  • Timothy Smith
    edited April 2011
    gdb wrote: »
    I wish.
    It would be nice to swap out cartridges on headshells for comparison and just have to readjust the counterweight and anti-skate.
    The few times I have seen used headshells, they were asking the better part of the $124 (new) I paid for the THorens TD-160 back in the mid 70's.
  • DeadFeat1
    DeadFeat1 Posts: 51
    edited April 2011
    All of the suggestions look good. I would second the Grado suggestion
    Don't forget to enjoy the music...
  • JPSmario
    JPSmario Posts: 142
    edited April 2011
    had a shure's for years (M91ED, then V15 Type II), switched to Grado a few years ago and haven't looked back. cost more, but was money well spent.
    Good luck
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • Timothy Smith
    edited April 2011
    I ended up buying the Shure M97xE thru Amazon for $54.
    Sounds great. Better than I remember LP's ever sounding, but I suppose my equipment has changed for the better (except the Thorens turntable which has stayed the same for 30+ years) since I was last playing vinyl with any frequency.
    Thanks again for your help everyone.
    Tim
  • Fongolio
    edited April 2011
    I'm using a Shure V-15 Type III on my Thorens TD-160 with Mission 774 Mk I arm and it sounds awesome. The Mission arm is a recent aquisition and mod but totally worth it. That cart should work great on the original Thorens arm.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • JuanR
    JuanR Posts: 718
    edited April 2011
    I use a Shure M44-7 on my Technics SL1200M3D, and it sounds good. But I am also curious to see how this compares to the Denon DL-110 or Shure M97xE. Can anyone give me a comparison on the M44-7 vs the other two I mentioned?
    I'm looking to try one of them out but not sure which one to grab (Denon DL-110 or Shure M97xE).
    Juan
  • newrival
    newrival Posts: 2,017
    edited April 2011
    Tim what about that skeleton transcriptor?? :)
  • Timothy Smith
    edited April 2011
    newrival wrote: »
    Still have it but I haven't played a single record on it.
    It is a thing of beauty though. All kinds of stereo stuff in the basement, but guests invariable stop and say "what the heck is that?"
    I will take a picture and post it.
