Power amps
jim 249
jim 249 Posts: 347
edited April 2011 in 2 Channel Audio
Can power amps do weird things with sound or is it they work or don't work? Can they alter the sound to not sound clear or distorted?
Post edited by jim 249 on
  • quadzilla
    quadzilla Posts: 1,543
    edited April 2011
    yeah, if the power amp has a problem, it can do "weird things".
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    treitz3 Posts: 19,945
    edited April 2011
    Help us to help you. What is it that you are hearing and what type of amplifier do you have?
  • jim 249
    jim 249 Posts: 347
    edited April 2011
    The sound is not stable. It varies in volume and tone, really does sound strange. The amp is a Nakamichi PA5-II. I am going to try my Rotel RB970BX. I hope it has the power to drive my 2.3TL's. The cd player was swapped out and still the same. My turntable also will do the same thing. If it is not the power amp than the preamp might be bad.
    edited April 2011
    Sounds like it might be the pre. Switching out the amps will help determine that. It could be something as simple as needing some DeOxit on the controls or RCAs, or it could be something more serious.
    t...3 and others can help you diagnose this better as you start experimenting with your set-up.
    Hope it's something, simple!
    cnh
    edited April 2011
    Try the Rotel at lower volumes and get back with us. What you are experiencing is not normal, as if I need to tell you this....
    nooshinjohn Posts: 25,877
    edited April 2011
    It may be time for the Nak to be refreshed as well. THat PA5 is a great amp worthy of the cost to restore.
  • jim 249
    jim 249 Posts: 347
    edited April 2011
    Swapped amps, sound cleared up. Will play for a few days to see if it holds, then will swap back to the Nak5 to see if it comes back. Thanks for the suggestions!
  • Goth child
    Goth child Posts: 38
    edited April 2011
    Is the Nakamichi a common ground power amp?
