Bi-Pole/Di-Pole Speakers
EndersShadow
EndersShadow Posts: 17,718
I am in need of a pair of bi-pole/di-pole speakers. Prefer if they are all black, have the ability to be wall mounted using keyhole mounts and are 8ohm.
They will be replacing my Monitor 40's.
No particular model prefered over another as of right now. Will have funds in the next few weeks to purchase. Prefer under 250 with shipping, and the more under the better :biggrin::smile:. For shipping estimates my zipcode is 46260.
Post edited by EndersShadow on
  • dougr
    dougr Posts: 124
    edited April 2011
    PM sent
    ______________________________________________
    RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable :)
    edited April 2011
    PM replied
    edited April 2011
    To give you an idea of why wallmounting is required, I attached a floorplan of my place with the speaker setup. Couple of notes:
    Due to the size of the Monitor 40's I cant mount the right one in the current position. Its location is marked w/ a SR 1 whereas with keyhole mounting and it not sticking out as far I could mount it is SR 2. The left surround will stay in the same place.
    Also note the Monitor 60's will be replaced by LSi 15's and more than likely the PSW 125 will be moved near the chair and a half (damn neighbors :smile:)
    edited April 2011
    Some models I would be interested in are:
    1. FXi A4
    2. FXi A6
    3. FXi3
    4. FXi5
    5. FXi30
    6. FXi50
    7. LS f/x
    edited April 2011
    bump
    edited April 2011
    still looking bump
  • artinaz
    artinaz Posts: 185
    edited May 2011
    hey lets me know if you would be interested in the f/x 500
    edited May 2011
    My bi-pole/di-pole needs are on hold for now. I replaced my Monitor 40's with Primus 162's by doing some moving around and it sounds a bit better surprisingly. Going to hold off on any other purchases besides the LSiC I am getting from Doro and possibly a external DAC for the office.
    All parties that PM'd me I appreciate it and will hit you back up if things change.
