Blackstone TL3s for surrounds w/ LSi9s?
PrazVT
PrazVT Posts: 1,607
edited April 2011 in Speakers
Hey - would the TL3 speakers work as surrounds mounted on the wall w/ an LSi9 / C based HT setup? This for my cousin - he's been debating how to go with surrounds. LSi7s / FXs will need stands and take up space (and are more exp) - it looks like the TL3s use the same tweeter / woofers as the LSi series and seem robust enough spec wise. Sub will most likely be an Epik Legend (per my other thread).
Does this sound like a doable option? This is for a 16 x 18 room. Speakers would probably mounted behind and to the sides of the main couch. The TV / HT area is not exactly centered with the room - the entrance is an open area to the right side.
- Praz
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
Post edited by PrazVT on
  • dnoyeB
    dnoyeB Posts: 114
    edited April 2011
    I thought about that myself. Folks scared me away from it. I'd like to see how it works out. A sound calibrating AVR should be able to blend the two different speakers.
    I had an AVR and it did an incredibly job of balancing my Cerwin Vega center with my M70 fronts. I didn't notice it until I returned the AVR and went with my old one again.
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2011
    Hmmm okay thanks guys. We realized that if the rears were mounted on the walls, they'd have to be done so at odd points on the wall due to the way the HT area is positioned. ie. it's not exactly in the center of the room. So scrapping that idea - most probably will go w/ bookshelves on stands.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
