$800 Amp--> Odyssey Stratos vs. Parasound HCA-1500
I-SIG
Any thoughts on these? They cost virtually the same, NIB, both have solid warranties, pretty similar power, etc. Thanks!
Wes
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
What about ATI AT2002 or possibly AT3002?
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
If you are gonna try the 3002 make sure you not only have a 20+ amp circuit but that the recepticals are also of this type.
The review I read said that a 20amp circuit was necessary for the 7 channel model. I'm only planning for two at this point, so I should be fine.
I would go with the proven entity, Parasound. I have been hearing more about ATI, so they may become more mainstream at some point, as a standalone manufacturer.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I-Sig,
I can't speak to whatever review you are referring to, but check the owners manual, page 8, bottom left.
http://www.ati-amp.com/manuals/at3000manual.pdf
The info may not be correct, but it does refer to the entire series.
Best Regards,
Rick -
If it matters, the ATI's are a 100% USA product, unlike Parasound.
It also seems that, from reviews, they have very similar sounds inspite of the ATI's different design, the ATI has more headroom, and the ATI costs about the same for similar power.
Hey I don't work for Parasound, so it doesn't matter which one is considered to me.
I know Parasound and their products like my own car, but have no clue about ATI, so it would never be an option for my pocketbook. All I see is paper, and a couple reviews. The Audiogon listings that have been around are mostly dealers, very few used....maybe they are just really good. I go for proven gear, not back scene manufacturers. Maybe in a few years people will start paying closer attention to ATI as a standalone. If you want to be different then its a no brainer.
Looks like just a couple values are different, and that is inherent with use of different parts and design...big deal. There are also some specs I don't see mentioned with the ATI. If 100% USA is what you like, then why even consider 75% of the brands out there? You basically help your whole process if that's the case.
I am sure whatever decision you make will cause sound to come from the speakers.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
LOL... :cool:Originally posted by dorokusai
I am sure whatever decision you make will cause sound to come from the speakers.More later,
Tour...
Vox Copuli
LOL! I know sound will happen, just trying not to make a huge mistake.
The ATI will NOT be a huge mistake ...
Get a listen if you can.
But if you are gonna go with the 3000 series I would make sure from the manufacurer what type of plug is on the end (See the reference to the PDF I posted above) -
I used a Parasound HCA-1500A on my Maggies (Magnepan MG12s). Great amp, very good bass control on the panels. If you'd like more info on the Odyssey go over to the Planar Asylum . Lots of Maggie users love them.
You're probably right. There a dealer up around Phoenix that I'm gonna make a run to this week. I may take my RT55i's so I can listent to them on *MY* speakers. I sent ATI an e-maillast night, so we'll see...
I-Sig - I meant that in a good way, not to be smart assed. I don't think you have mentioned a bad choice in any of your posts. Sometimes you have to take a leap of faith, and buy ATI....or buy Parasound....or buy NAD....get some information, read your **** off, and demo if at all possible. Some of these will not have a demo near you, so you will be **** out of luck.
I wouldn't buy ATI if it had a hookers' mouth in the backside, but that's just me and my interpretation of information and knowledge....essentially that means nothing. Noone said it would be a huge mistake to buy an ATI, so I have no idea where that is from.
If you don't like it, you sell it, plain and simple. Buyers remorse is just learning what you want to hear. Buy one of them damnit!
I know I know!
I think this might help me some if y'all can answer for me: How do planar speaks, like the Maggies, compare with my old SDA's, especially on the highs? Thanks!
Where is a stratos for 800.00 NIB???Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Maggies are not all that different as far as the highs go. Where they are very different are in the bass and the imaging.Originally posted by I-SIG
I own the 1.5's and while they go low enough for some music, e.g., acoutic jazz, light classical, IMO they are not rock or full orchestra speakers.
While the 1.5's will not present a 20' wide soundatage as SDA's do, they will image deeper and more precisely.More later,
Tour...
Vox Copuli
The Para's and the Stratos seem to be about the same price, just slightly above my $800, about a grand or so.
Here's the scoop from ATI:
Dear Wes,
Our AT2000/3000 Pure Balance amps are not common grounded nor are they bridgeable. Re: 20 amp circuit, you are correct, only the AT3006 and AT3007require a 20 amp circuit.
Sincerely,
ATI
So, I'm gonna rule them out for now because I don't want to build a AI-1. I guess I'll start checking on the Parasound dealers around Tucson.
I thought the odysee stratos was over a grand? i've never heard one myself, but from what i heard on word of mouth, i would go with the odysey if you see it new in box for 800.00!!!Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
The Stratos has a 20 year transferable warranty, you don't have to worry about buying a new one. I usually see used ones with the cap upgrade go for around 700 to 800 on Audiogon.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
That's not too shabby....isn't it Nico who owns a Odyssey? Where has he been hiding all this time?
