Larry's passive rings- Wanna trade?
Rev. Hayes
I bought a set of rings for SDA 2As that I had just bought the same day and was planning to upgrade. After listening for few months I decided not to do the project and sold the speakers.
I'd like to use the rings on my Monitor 10's but I need the 10" passive rings not the 12" that I have.
Is there any chance someone would like to swap?
Sounds good to me...
Post edited by Rev. Hayes on
If you can't find someone to swap with, I can take them off your hands for what they originally cost you, so you can buy a new set. I was thinking about buying some and now seems like as good a time as any if it will help you out.
Rev,
Send me your addy again and I will send you the 10" passive rings.. -
Hi Larry,
I'm also interested in purchasing some rings. I tried sending you a PM, but I'm not sure if it went through. Please drop me a line.
Thanks,
Brian -
Hi Larry,
Thanks,
Brian
PM Sent... -
