system set up
supertec
supertec Posts: 12
edited March 2011 in Forum Testing Area
need to know if i need to add an amplifier or upgrade my integra dtr 7.3 avr for my speaker setup which consists of lsi 15 left and right; lsi center; velodyne sub; lxi 7s for rear and back surrounds. i believe lsi 15s were rated at 200 watts each @ 4 ohms and avr is rated 100 w/x7 channel @ 8ohms. does this seem to be correct? i am a novice in ht systems can any body help?
Post edited by supertec on
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    LSI,s are 4ohm speakers, yes you need an amp....................................
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • supertec
    supertec Posts: 12
    edited March 2011
    thanx for the info. now i need to know what kind of amp would fit best.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2011
    You'll need an amp with some cajones to power all those speakers! :eek:
    Try posting in the electronics forum! :wink:
