Is A.I. worthy of a purchase?
Ron-P
Ron-P Posts: 8,516
edited February 2002 in Music & Movies
It streets 2/26. I have not seen it and none of my friends have either. So, is it any good?
Peace Out~:D
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • Aaron
    Aaron Posts: 1,853
    Overall I didn't think the movie was that great. The story is somewhat intriguing and the visuals are pretty amazing. The story is one that goes on forever, and then goes a little further with a totally whacked-out ending. It reminds me of the way that the plot for "Contact" evolved. I'm guessing it will probably be a great DVD in terms of audio and video quality. I personally wouldn't buy it, though.
    Aaron
  • RuSsMaN
    RuSsMaN Posts: 17,987
    What Aaron said.
    Interesting concept, but too long, and goes way 'out there' further into the story. Barely worth the rental.
    Cheers,
    Russ
  • hamzahsh
    hamzahsh Posts: 439
    If you like Pinocchio then you'll like A.I too.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • johnnyamerika
    johnnyamerika Posts: 382
    Not at all worth the purchase, I would maybe rent it if there was absolutely nothing else to rent.
  • Ron-P
    Ron-P Posts: 8,516
    Thanks guys. I'll give it a rental first.
    Peace Out~:D
    If...
  • Billm57
    Billm57 Posts: 689
    just stop the movie right before the last half hour..you will know what i mean after you watch it..they had a great unintentional ending then they added another 1/2 hour and ruined it...
