Blackstone TL3 center
BigA524
BigA524 Posts: 63
edited March 2011 in Speakers
looks like its the height i need for it to fit. handles up to 125 watts. Is this doable with my amp at 200? or just plug it into the avr?
is it a decent center?:confused:
Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
Post edited by BigA524 on
  • nhhiep
    nhhiep Posts: 877
    edited March 2011
    125W is actually a lot. 200W from your amp is the max. normally, I doubt you will run more than 50% of your amp.
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2011
    as long as you don't do anything stupid with the volume knob, you'll be fine
    keep in mind being stupid with the volume knob while underpowering a speaker is far worse that with overpowering one......so stupidity with the volume knob is an issue no matter what
    long and short, avoid driving them to noise and distortion and you should be fine
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
    edited March 2011
    Personally, I think it will get lost sitting in the middle of those RTI 10's. You might have to boost the speaker levels on that center to keep the front soundstage coherant. Even then, I still think it may be too small. How big is the room ?
