No joy w/ comp/tunes
leftwinger57
leftwinger57 Posts: 2,917
edited March 2011 in Electronics
Hi guys, Sorry to sound like a broken record but here's a negative update to my ongoing problem.As per some of you guys suggested to use 3 pronge plugs in to the devices and by process of eliminatation something should give. Well I went to Home Depot and picked up a bunch of the adapters ,rewired and labeled all plugs. NOTHING, THE ORIGINAL HUM is still there which means it's either the cable it self, the length, or the splitter. I do have 2 more splitters coming and not thinking I should of laid the cable out before securing it.I really hope this isn't a lost cause, I would like some tunes from a different source FM RADIO in NY really sucks....Thanks for the input ,I tried but hum is here to stay........LW
  • w_coyote
    w_coyote Posts: 66
    edited March 2011
    Shot in the dark here but have you tried different input on the receiver. Might be worth a shot. I have a denon 988 and use the ipod input without any problems.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2011
    From this thread: http://www.polkaudio.com/forums/showthread.php?t=117320
    newrival wrote: »
    50' of RCA is quite a bit. Seems highly suspect as the cause, but I'm no tech. I'm sure others will weigh in. I know that a long time ago, I bought a cheap (~30-40 bones) 15' RCA and had the exact same problem. I run lots of long distance cables now but theyre all digital (HDMI and DVI-D @ 50' and 80') and theyre about an inch thick. I imagine anaolg is even harder to pass over that distance without some serious cable, not to mention proper shielding if passing by electronics or electric.
    jinjuku wrote: »
    Most likely the 50' runs of RCA. That is a heckuva long run. Get some two meter cables and repeat the process and see if you get the hum.
    You REALLY need XLR to do this.
    ben62670 wrote: »
    You need to run a digital signal over that long of a run.
    tonyb wrote: »
    Sounds like the best option for him. A 50 ft run of rca cable won't cut it. Go wireless, or digital.
  • mdaudioguy
    edited March 2011
    You need to run a digital signal over cable or find a wireless solution or move the computer closer.
