Bookshelf
Ericw2431
Ericw2431 Posts: 228
edited March 2011 in Speakers
Ok so im thinking im goin to down grade from tower to bookshelfs up front in my ht......are the rtia3's best for ht?! or should i move over to another brand?! )klipsch rb81)......i would like this to be my last upgrade!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Post edited by Ericw2431 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    klipsch would not mix with the Polk's well. Why do you want to down grade?
    Ben
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2011
    I agree with Ben, I would keep the Klipsch out of the mix. I would think the A3's would be a good speaker for HT, but keep in mind it will be a considerable difference from what you are used to with the A7's. Like Ben said, why are you downsizing?
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • cubdog
    cubdog Posts: 835
    edited March 2011
    Ericw2431 wrote: »
    How can you downgrade and upgrade at the same time? The Klipsch would be a bad fit regardless.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2011
    A3's are good. I guess as other stated why do you want to move from a tower to bookshelf now? Space limitations? Moving?
    Already sounds like a good set up not sure why you would want to change it up.
  • B Run
    B Run Posts: 1,888
    edited March 2011
    Hey holler at me about your A7's, im in Austin and am always looking for some new speakers.
  • Ericw2431
    edited March 2011
    Ok well what i was trying to do is have a smaller profile....so maybe lsi15?! would they be good for home theater?! anybody near or in austin that will upgrade my crossovers if i do get them?! i heard they are much better with the sonicaps and dayton?! well i will get lsi15 IF and only IF they are good or better then the a'7s for ht.......and how bout my lsi9's should i upgrade the Xo on those?! will THEy be better in ht?! please help!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Ericw2431
    edited March 2011
    and about the a'7s i already promised my brother them..but i do have some a'3s with paradigm speaker stands....
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Ericw2431
    edited March 2011
    Bump!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • vivid2012
    vivid2012 Posts: 6
    edited March 2011
    If u really wanna a nice bookshelf speaker, you could go with this Pioneer Bookshelf Speakers. Nice performance. Great to use. It might meet your needs well. Hope u find the best bet.
  • Ericw2431
    edited March 2011
    Pioneer?! are ya'll playing with me?!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Ericw2431
    edited March 2011
    Im trying to get a good L/R speaker wether it can be done with a bookshelf or a tower...i really want a bookshelf dough.....but if.a tower is better for ht than.tower it, will have to be....please im open to suggestions on either.bookshelf or tower......serious replys please
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2011
    Ericw2431 wrote: »
    I guess I don't understand your problem....your sig says you have RTiA3s and a PSW505 - that right there is ' a good L/R speaker' and sub.
    What is it that you don't like?
    I had a very similar L/R/C combo with a sub and thoroughly enjoyed the sound - quite 'good'.
    Are you looking for 'better'? :confused:
    edited March 2011
    What kind of space are we talking about, because as Erik says above...your current combo would work fine in a small to mid-size (not too big) space. I run a similar set up in that size room and with the Polk sub it's FINE for HT. And not bad at all for 'music'!
    cnh
  • Ericw2431
    edited March 2011
    'better' yes if there is music.isnt a concern of course I dnt want a speaker to sound to bad dough and if der is a better bookshelf for.ht nd if not than the rtia9s or a speaker in its price range
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Ericw2431
    edited March 2011
    Bump
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • cstmar01
    edited March 2011
    Ericw2431 wrote: »
    huh?
    seriously what the hell did you just say because I can't understand any of it.
    If you want a good book shelf for HT and music LSI are a good way to go. If you want to keep towers than run RTIA9's for HT and LSI can be good for music and movies. If you just want to do HT then do RTI.
    Its really what you like personally. I could tell you all day long that Paradigm S8's are the way to go but unless you hear them for yourself you would never really know.
    Once again what do you mean by better?
    Do you want something with better bass response? More clarity? warmer sound? darker sound? a more detailed sound?
    Are you having a problem with imaging? room reflections? You give no idea as to what you mean by a "better" set up. there are several things you can try first before going and buying new speakers.
    Such as speaker placement. Source, room treatments, etc before jumping and saying its always the speakers. Normally placement will be huge and if you are craming huge towers into a tiny room well your not going to get what you are looking for normally.
  • Ericw2431
    edited March 2011
    WHAT IM ASKING is what speaker "pair" of course.... can i get for Ht whether its a bookshelf or tower thats Excellent at HT and decent/good for music.....Budget is 1000$ it can be used or refurbish....Im not saying my system sucks im just saying is there better in that price range!! and by "better" i mean dynamics/clarity/midrange ...i mean like seriously?! common sense im asking for a better over all performer! (if there is one) in that price range!!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Erik Tracy
    edited March 2011
    Ericw2431 wrote: »
    Geez dude - this has been like pulling teeth to get information out that would be of any use.
    Vague comments get vague/puzzled replies.
  • cstmar01
    edited March 2011
    Ericw2431 wrote: »
    Common sense? Common sense is knowing that stating you want something "better" but not saying what you are looking for, nor lacking currently is a good question.
    The term "better" is wayyy to subjective as my better could be your best, and my better could be someones worse.
    The RTI are good for movies and music they are nice as well. what more can I tell you? The LSI's excel at music but once again do a good job in HT as well.
    We don't know what you've heard before nor do we magically know what you want. You need to learn to post what you are looking for and then its a lot easier for people here to help you rather than just stating you want better.
    There are several other speakers too that you could look at but the other problem you face is that if you are only upgrading the front L/R for HT then the center channel should also be upgraded. Timbre matching is important if you are doing a lot of movies as otherwise it will sound a bit off.
    So if you are wanting the RTI line keep it all RTI, if LSI is want you want then you will also need to figure in getting a LSI center. If you went with Paradigm then keeping the front 3 at least all paradigm.
  • Ericw2431
    edited March 2011
    OK before yal start quoting me im'a quote Erik
    "Are you looking for 'better'?" im assuming he knew what i ment!
    and i know that i have to timber match, but im asking for suggestions
    on the front L/R Il take care of the center once i Know what L/R ima get....
    not the basic line of "go out and listen to your self"
    I am not capable to go around alot.... the only dealers iv went to only got B&W and paradigm/Klipsch
    Im not asking you to read my mind im asking for suggestions in which ya'll think excel in Ht
    and do decent in Music!!!!.....I KNOW MY SETUP doesn't SUCK im Asking if theres a BETTER HT performer out there!
    AND BY "BETTER" As i stated before a more Detailed ,Bass response, controlled, Dynamics, Is there really more words to describe?! You all have heard a speaker that cought the drum in your ears when it came to HT....MAY I PLEASE know wich speaker it was?! and why better?!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • cstmar01
    edited March 2011
    Ericw2431 wrote: »
    Def Tech Mythos ST
    Paradigm S8 V3
    Martin Logan Spires and Summit X's
    I think they are better. :rolleyes:
  • Ericw2431
    edited March 2011
    i can not afford the mythos altough they are OUTSTANDING!
    and as for the paradigms idk how much they are
    If im correct i did say in the 1000$ range?!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2011
    I'm fairly certain I have internal brain bleeding at this point...
    At a minimum you'd need to replace all your front soundstage at once. You may be able to pull off an LSi front end for that price. As for if they're better, you've got a pair of LSi9 in your 2 channel righ, just bring them into the LR and decide for yourself.
    There are plenty of other brands out there that have products in that price range (Klipsch, Energy, Definitive Technology, B&W, KEF, PSB, etc etc...). You'll have to go listen and see what you like, everyone's ears are different.
    I don't know what you have for audio shops down there in Austin, but I suggest you get yourself up to a few places and listen to some other brands and see what you like. If you have a Best Buy with a Magnolia you can listen to 4 of the brands I listed above). If not, make a trip up to Dallas and hit some of the places up here.
    We're not going to tell you what's better because you need to decide that for yourself. The RTi series is very competitive at their price point, but yes there are other options.
    Good Luck
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    Good lord Eric - Sit and think about what you want to ask. Then open up MS Word and type it out. Run the damn spell / grammar checks and then get a friend to proof read the question. Then, only then post it here. Because it's painful to read!!
    This is about par for his threads :) I'm not trying to be mean - but the clearer you are, buddy, the easier it is for folks to help.
    +1 for the Rti A3s. Would be the cheapest overall option.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Ericw2431
    edited March 2011
    i don't know if 1000$ is any where near cheap for a pair of speakers!? probably for you that get 75k+ a year! But what i am trying to ask is are there better speakers for Home theater in the 1000$ price range! thats all i ask for! if lsi9's are as best as it gets then i will set them back up in the HT! if the rti a'9 or A7's where better for HT then i will get them back! all i ask is if theres better for the Buck im spending here!!! Thats all i ask for!....and yes my grammar isn't proper, but you all can get basic understandings of what im asking for!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    Ericw -
    The RTi A series was designed for HT. You already have others of that line. You want smaller speakers in front. RTi A3 < $1000. Buy them.
    Use the rest to modd the xo's on your LSi 9s. Be happy. Stay in school.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • wutadumsn23
    edited March 2011
    I think the answers have been given to a question he continues to ask, post after post. Hopefully he has read them and takes the advice given.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • cstmar01
    edited March 2011
    Ericw2431 wrote: »
    Once again, we can not tell you what is the "Best" as we all like different things. Yes people can agree upon things like speaker A is normally better than speaker B but once again YOU HAVE THE SPEAKERS LISTEN TO THEM!
    You seem to want us to tell you what to like. You already have LSI's and you have RTI's so why don't you just try it out to see which one you like better???
    Seriously, its like asking if you like red apples or green apples better. We have no clue and if you have both in your hand then your not really doing your part in this.
    I also ask please consider doing room treatments etc as well or making sure you have proper speaker placement as that will help you in the long run.
    if you really want to be told what to do, then do this. send me all the money you were going to spend via paypal and I'll keep it for you. that way you don't get anything different or have the confusion of what to do with your money.
    Also you keep jumping from floor standers to bookshelfs. Pick one.
    Also you keep jumping between two speaker models you already own. Try them.
    If you want to try others you need to either A go demo them to see if you like their overall sound, or B try to listen at someone's house sometime. You live in a far bigger city that I do and yet can't seem to listen to anything.
    I make it a habit of trying to find an audio store when I go somewhere. Right now I'm going to go to one about 7 hours away from me just to see if I can listen to something and planned my trip a different route so I can go there. Takes a little bit of research but if you can't put in the time and the effort then your not going to get the reward.
    tonyb Posts: 33,072
    edited March 2011
    Ericw2431 wrote: »
    Last upgrade ? Hardly....it's an itch that forever needs scratching. What your asking is akin to what candy bar tastes the best for the money. Lots of flavors in speakers, and most all manufacturers have a following of happy customers. Personally, I would upgrade the subwoofer and amps before the speakers. Thats just me though. Also shop used for the best bang for your buck like Audiogon or Craigslist.
