whats rta about the rta 11tl's
soundfreak1
Lest I'm mistaken the "rta" refers to the "open baffel" style and ofset tweeter like in the rta 12b's someone splain for me please!
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
It doesn't refer to an open baffle array at all and the RTA12 is unlike the rest of the line...more of a true real time array than the others. The RTA12 isn't an open baffle design either as the term "open baffle" is more commonly associated with a loudspeaker that is constructed without a cabinet, just a fascia or single plane.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Understand on the "open baffle" I was speaking of not in a box,open air might be more correct but I thought the rta had to do with the set back tweeter in that it would help control the faster speed of the high freq. Set back so it arrives to the ear more in time with the low freqMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
That's what Real Time Array means for Polk....so yes, you are correct. The transient response of the tweeter is faster than the mid bass/ bass driver so it "aligns" the listener with both at the same time. I'm sure there are fancier ways to explain that but I'm just a layman...and I'm betting you're not the average listener anyways.
A "poor mans" RTA was used via loudspeaker stands on the earlier Polk Audio Monitor series. The stands employed a rake, 4 degrees or such, that essentially....and effectively, created the same effect. Vandersteen is probably the most well known proponent and designer of a staggered or RTA style array although most ppl wouldn't know it given the aesthetics of the brand.
Either way, the RTA12 is neither open air nor open baffle by definition. I'll add more information about the other models later when I look up my notes since there is confusion about the other models.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
