preamp or cdp for better sound
scottyboy76
scottyboy76 Posts: 2,905
edited March 2011 in Electronics
I have marantz monoblocks through a nice marantz sr8000.
They fuel a set of sda 2bs, without upgrades, or dcm tf 400s.
After visiting jerry j12, and listening to his awesome, expensive tube gear, even over smaller tf 250s, and the sdas he sold me, i could not believe my ears.
He was using an expensive jolida cdp, some badass tube amps, and a smallish pre, cant remember the make.
I want to approach the effortless sound at high volumes i heard that day.
Im pretty much quitting on ht, because we just dont use it that much, and we love the 2 channel setup for music.
I have direct music channels, the sonic tap stuff, also a denon dcm 460 carousel cd player and a lg bd550 bluray, to play cds, not garbage, but nothing like the better stuff, i guess?
Have a decent technics tt, nothing special, but it works as new, and many, many lps from the golden years of rock, late 60s to 90s.
With the smallish budget, even with the intent to sell or trade the marantz rec. and three of the monoblocks, as well as offering a 322 dollar brandsmart gift card, i dont think i will be able to acquire both a quality preamp and a really nice jolida or oppo level cdp.
My questions, first, is a quality pre, paired with two 125 watt ma500u marantz monos going to be a marked improvement over the same marantz monos, paired with the marantz sr8000.
If not im going to concentrate on the quality cdp.
Im hesitant to jump into getting rid of my gear, it took me awhile pouring over cl ads to find smoking deals on quality stuff.
I just dont have the experience many of you guys do, swapping and tweaking components, judging which changes give the best results in general terms.
Any impressions or opinions from personal experience would be very much appreciated.
Thank you
humpty dumpty was pushed
Post edited by scottyboy76 on
    treitz3 Posts: 20,006
    edited March 2011
    Tell Jerry to sell you some of the gear he has. That'll make the biggest improvement on your rig and with your budget. Give him hell until he gives.
  • thsmith
    thsmith Posts: 6,082
    edited March 2011
    Get the AVR out of your 2 channel listening and put a 2 channel preamp between your AVR and 2 channel sources.
    YMMV
  • danger boy
    danger boy Posts: 15,722
    edited March 2011
    every piece of stereo equipment makes a difference in the overall sound quality.. so start with one piece, then add to that till you are satisfied with the sound.
    adding two or more pieces of equipment is a bad idea.. you'll never know which piece made the most difference.. get one piece.. listen to it for a few months then add another piece.. it takes time.. but it's a great adventure. :)
    PolkFest 2012, who's going>?
  • scottyboy76
    edited March 2011
    besides, have you seen that guy treitz, you would not know what a nice guy from just looking.
    I dont think i want to harass him about anything.
    Maybe if you hold him down, i could run in his new house, grab a few boxes and take off.
    Now what, wanna hold jj down.
    Seriously, the guy has lots of incredible gear, and its all up for sale or trade, but i dont think he is into my ht stuff i have to trade.
    And i believe his stuff is well above my price range, even with trades, but i will give him a ring tonight.
  • scottyboy76
    edited March 2011
    Thanks for rplying everyone, but im not sure about one response.
    I have a so so audiosource preone/a preamp i traded jerry some speakers for.
    I have had it hooked to the monos and running sdas.
    The source was directv sonictap, and denon cdp.
    It was okay, but the marantz rec. sounded better, neither had nearly the detail, quiet background, and easy power of jerrys stuff.
    I understand he has very expensive gear, but i really think a higher quality pre, and or a jolida or oppo cdp would get me much closer.
  • megasat16
    megasat16 Posts: 3,521
    edited March 2011
    What you are trying to achieve requires many upgrades. You can start your upgrades from the CDP or anything you want. You'll hear a marked improvement everytime you upgrade.
    But if you want to spend your money for the most improvement out of your rig as it stands, get a nice preamp first. Your marantz amps are mainly marketed for the surround sound at one time even though they are monoblocs. I am not a fan of them either.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Get a nice tubed pre first. Then get a good DAC or CDP.
    Ben
  • Obsession18
    Obsession18 Posts: 191
    edited March 2011
    I added a Jolida JD-100 CD player to my system and it made a significant difference, and I'm using a Pioneer Elite as a pre/pro feeding a Parasound amp. The great thing about the Jolida is you can tube roll and improve things even more (I'm still using the stock tubes). Eventually I will add a dedicated preamp with a HT bypass, but for now my Linbrook Signiture Systems are sounding pretty sweet.
    I purchased my CD player from Jolida.net, great buying experience, they are $649.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • ben62670
    edited March 2011
    Wait till you get some better tubes. I do not understand why they even ship a nice CDP with those tubes. Hopefully someone will chime in and recommend some decent tubes. Also you can use the search function:wink:
    Ben
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2011
    Jolida cdp is only $559
    http://jolida.net/hotdeals.htm
  • Gulfstrings
    Gulfstrings Posts: 313
    edited March 2011
    "My questions, first, is a quality pre, paired with two 125 watt ma500u marantz monos going to be a marked improvement over the same marantz monos, paired with the marantz sr8000.
    If not im going to concentrate on the quality cdp."
    Maybe this will help a little ... I had to choose between two "good" CDPs to use in my primary system. Both are single disc players, one an Onkyo DX7555 the other a Marantz CD5003. Ultimately, I had to do an apple-to-apple and allow the players to "speak for themselves." In other words, bypass the AVR processor (used as a pre). Both sounded much better. The "pre" just couldn't reproduce as well as either player could via analog.
    So, if I've understand one of your considered options correctly, my suggestion would be to score a good CDP and let its processors do their thing. BTW, the Onkyo CDP won out in my comparison but the Marantz is doing it thing in the next room.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
    tonyb Posts: 33,072
    edited March 2011
    ben62670 wrote: »
    Agree here, alot of members have a tubed pre with SS amps and are pleased with the results. Also agree with the one piece at a time theory but would also add an upgrade to your cables in the mix. If cdp's are up your alley, plenty of good used ones on the market for cheap, since alot of people have been going the downloaded music route. Which if you think you may do that, the dac is more important than a cdp, and can be used with both a cdp and computer for music. So I guess I would vote for a tubed pre first, then a dac, then cables, and if you still want,a good used cdp in that order.
  • scottyboy76
    edited March 2011
    i appreciate the advice, i sorta feel the same, as far as a dac or cdp to start.
    I mean the marantz rec. and monos are not terrible, but my sources are severely lacking.
    Im going to check out exactly what a dac is, and if it would be more appropriate for me.
    If anyone has one for sale please post it, i will check it out on fs.
    By the way, i always thought downloads are the worst sound quality out there.
    admittedly i know nothing about the tech of it all, if there are quality sources avalable without breaking the bank, please let me know.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited March 2011
    It all starts at the source! While I have resisted Jesse's recommendation to go SACD, I've found my source (dac/transport) to have had the most impact on the sound.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • george daniel
    george daniel Posts: 12,096
    edited March 2011
    yep,, source,,yep.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2011
    Throw me in the tubed pre category.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • Obsession18
    edited March 2011
    ben62670 wrote: »
    You were quite correct about better tubes!
    I put some Psvane 12AX7 grade A tubes in my Jolida JD-100 last Friday and left the player on continuos play all weekend to burn them in.
    Monday night it was time to see what they could do, what a difference - tighter better controlled bass, improved detail in the highs, and alot blacker background, worth every penny!
    If you own a Jolida - GET RID of the stock tubes!
    2-Channel System
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2011
    My observations with over 35 yrs in this hobby:
    1. Simplicity-as few components as possible, get the electronics and excess cables out of the way.
    2. Speakers, speakers, speakers-if the speakers aren't right, nothing else EVER will be.
    3. Buy components in the "sweet spot" of performance/cost, unless of course you have money falling out of your ****.
    4. Cable selection and management-They don't have to be rediculously expensive, just good sound engineering, and properly routed.
    5. Quality vs quantity--always pick quality over quantity.
    6. Placement/room acoustics-self explanatory. Experiment with speaker placement; it makes a huge difference.
    7. Except for patterns of troubles or issues, pretty much IGNORE other peoples opinions of individual pieces of equipment. People tend to over-hype, both in the positive and negative realms.
    8. If you still find yourself chasing your tail, see #2.
    In the speakers vs source debate, speakers win everytime in my opinion; and I've learned this lesson time and time again throughout my audio journey. . Want proof? Take a $29 DVD player as your source and run it through a set of $5000 speakers. Now take a $5000 CD player and run it through $29 speakers (or, what the heck, $800 speakers)--wanna guess which system comes out on top? Of course you want a good source, no doubt, but the focus of your budget should be the speakers---
  • Conradicles
    Conradicles Posts: 6,343
    edited March 2011
    Very well said Steve!
  • steveinaz
    edited March 2011
    My recent setup has been pretty much the same for the last 8 years. The only thing that has changed (essentially) are my speakers---and what a difference. My base system went from sounding like ****, to rising to what I thought it was always capable of just by changing up speakers; I'm glad I stuck with my base components, with hindsight. I live pretty far away from any "real" audio that I can audition, so I have to rely on research and LUCK for the most part--and alot of trial and error; unfortunately trial and error gets expensive as it is difficult to locally sell used hi-fi. The progression looked like this:
    Pinnacle Classic Gold Towers-->Athena AS-F2-->Energy Connoisseur C-9-->Fritz Carbon 7
    Ironically, if I rated the above from BEST to worst (1 being best):
    1. Fritz ($1750. One of the best speakers I've owned in 35yrs)
    2. Pinnacle ($1000. Damn nice speaker with hindsight. Smooth treble, nice mids, incredible bass)
    3. Energy ($1300. Fairly solid, but too "HT" sounding. Strident midrange, but smooth treble. Bass was too resonate sounding)
    4. Athena ($600. Good bass, way too much treble--I'll just say it, they were awful.)
  • Obsession18
    edited March 2011
    Steve,
    You are absolutely correct about speakers making the biggest difference. The improvement in sound quality going from my Polk RTi10's to my Tyler Acoustic Linbrook Signature System's was huge. I did see an improvement going from a run of the mill blue ray player to the Jolida JD-100 CD player, but it was no where near the improvement the speaker upgrade provided.
    2-Channel System
  • Hawkeye
    edited March 2011
    While I'd agree in principle that speakers have the largest impact, Scottyboy asked about a cdp or pre. He does have a pair of SDA's so there probably won't be a change there.
    I'd still go with the source!!
    Gordon
    2 Channel -
